  • June 14, 2025, 01:14:36 AM
Author Topic: Ringmaster Mk II  (Read 2513 times)
Offline pat king
    • PDK LLC
Ringmaster Mk II
« on: July 14, 2017, 08:38:13 AM »
This airplane is essentially the same as the S-1B except it is for shipment outside of the USA. It is the shape and size of an S-1 Ringmaster with a thicker wing. This airplane is NOT legal  for OTS competition! The center rib is 16% thick. The spar is slotted for the ribs. The spar and ribs go together in “egg crate” fashion. The spar and spar caps have an “I” cross section. The 3” Bellcrank mounts suspended in the wing. The kit is laser cut, the CAD plans show all parts full size. The airplane has a 42” wingspan and 381 square inches of wing area. The kit includes the landing gear wire, the Bellcrank pivot wire, the pushrod wire, the landing gear clamps, and screws. The engine mounts are hard Maple. The kits will sell for $76.00 plus 3 pounds shipping from the USA. The kits are cut to fit into a 4 X 4 X 24” box for shipping to persons outside the USA.  You can pay using PayPal. Full size .pdf files of the plans are available for $5.00
Pat King
Monee, IL
AMA 168941
