  • June 13, 2025, 07:15:32 AM
Author Topic: F82 TWIN MUSTANG Profile Scale  (Read 2038 times)
Offline pat king
    • PDK LLC
« on: January 12, 2019, 09:56:21 AM »
A 1 1/4" to the foot profile scale F82 Twin Mustang. The airplane is for twin .25 to .35 engines. The airplane has a 64 5/16" wing span, 654 square inches. It is 48 3/4" long from the tip of the spinners to the end of the rudders. It is 17 3/4" tall from the bottom of the wheels to the top of the vertical stabilizer. The wing is scale airfoil, and scale dihedral. These plans include three sheets 36 x 66 and one sheet 24 X 48 with full size templates of all parts. The plans are perfect new plots of the files. If you want a different profile scale subject this is for you. Panel line drawings or files at the same scale as the model are available. The kit has been revised to eliminate the original non scale airfoil and the flap on the wing center. The kits sell for $216.00
I kit the F82 in 5 sizes. The 4 larger ones have built-up wings. The MINI (.020) and this one have been updated to have the stock airfoil. The .15 size and .049 size will be revised. The Micro (.010) has a sheet wing.
Pat
Pat King
Monee, IL
AMA 168941
