  • July 31, 2025, 02:14:27 AM
Author Topic: COMBAT CAT  (Read 3032 times)
Offline pat king
    • PDK LLC
COMBAT CAT
« on: October 24, 2016, 05:42:14 PM »
This is a laser cut kit for the Combat Cat. The airplane has a 40” wingspan and 383 square inches of wing area. The wood is contest grade. The plans are CAD plane with all parts shown full size. The plans show the thrust line in the original position above the centerline of the wing and an optional thrust line centered in the wing. The kit contains parts for both options. The kit contains the bellcrank, control horn, pushrod, and music wire pin for the suspended bellcrank. The first kits will sell for $68.00 plus shipping from 60449.
Pat King
Monee, IL
AMA 168941
