  • June 13, 2025, 09:11:00 AM
Author Topic: CLOWN RACER KIT  (Read 2591 times)
Offline pat king
    • PDK LLC
CLOWN RACER KIT
« on: August 14, 2018, 10:00:49 PM »
This laser cut kit has the shapes and thicknesses from the Flying Clown plans from the AMA plan service. It is not for sport flying or OTS Stunt competition. It is designed for Clown Racing. The airplane is very strong and tough. The leading edge is made from ½” square Basswood. The spar is “I-beam” shaped. The Bellcrank is suspended on a pair of 1/8 ply Bellcrank mounts that span the first 3 ribs on either side. The Bellcrank mounts are hooked on the center rib, you would have to destroy the airplane to pull the Bellcrank through the wing. The center rib is 3 pieces of ¼ balsa laminated to give a ¾” thick center rib. The wing has adjustable leadouts. The ½” thick fuselage is ¼” basswood on the outboard side and ¼” Balsa on the inboard side. The horizontal tail parts are 1/8” Basswood, they have the holes for the sewn hinges.  The vertical tail is 1/8” birch plywood. The main gear is 1/8” Music Wire that straddles the fuselage and doublers. It is removable without disturbing the wing to fuselage joint. The engine mounts are ½” square hard Maple. The kit sets them 1” apart, the ½” vertical dimension allows them to be cut out to fit engines that are up to 1.3” (33mm) across the crankcase. The CAD plans show all parts full size.
The kits sell for $110.00 plus shipping of 3 pounds from Zip 60449. I will sell a full size .pdf file of the plans for $5.00 , there is no shipping on the plans they will be emailed to you. Thanks to Bill Bischoff for design input.
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: CLOWN RACER KIT
« Reply #1 on: August 15, 2018, 10:07:52 AM »
Thanks!
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: CLOWN RACER KIT
« Reply #2 on: September 06, 2018, 10:24:01 AM »
I have updated the design to have 1/8 Basswood skins on both sides of the fuselage and a 1/4" Balsa core. The price goes to $113.00 per kit.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: CLOWN RACER KIT
« Reply #3 on: September 28, 2018, 07:37:41 AM »
One more upgrade, the outboard wingtip is now a sandwich of 1/8 basswood center with 1/8 balsa top and bottom. There is no price change.  y1
Pat
Pat King
Monee, IL
AMA 168941
