Vendors Corner => PDK LLC Laser Cut Kits => Topic started by: pat king on June 08, 2013, 02:45:04 PM
Would anyone be interested in a 54" wingspan 536 square inch laser cut profile scale F4U Corsair? The airplane would have the standard Corsair bent gull wing. The bellcrank will be mounted through the fuselage on a pin. The rib profile will be symmetrical. the airplane will not have flaps. The airplane will be able to compete in profile scale or be a great sport flier. With a good 45 the airplane should be capable of level flight, inverted flight, inside loops, outside loops, figure "8" , wingovers, etc. The gear will be mounted on the wing. I would think the kits will sell in the $175.00 range until I find out otherwise. I have all the structure and building methods worked out for the leading edge and the bent section of the wing. As you can see the leadouts do not go through the wing. The scale shape wing has 20 degrees of anhedral on each side in the first panels near the fuselage. It then bends around to end up with 9 degrees dihedral on a side. Now I have to do all the rest of the formal drawing work.
Ty,
I have re-designed the gear and gear mounts. The gear exit the wing very close to the full scale position. I will post pictures of the finished plans tomorrow. I have to finish the cutting files. I'll let everyone know when I am ready for orders.
Thanks, Pat
Here are the finished drawings.
Pat
I am ready to take orders for the Corsair 54. Whoever has a $100.00 deposit to me by the 5th of July will get a kit in the first production run. I am presently not employed, so I really shouldn't buy the laser cut parts on speculation. The total for the first kits will be $175.00 , that includes shipping and insurance.
Thanks, Pat
Pictures Ty, pictures !!!
Thanks, Pat
Hey, Pat,
Do you sell the plans ?
Full size .pdf files of the plans are available for $5.00 , Paypal to:
patdk@aol.com
or check to:
Pat King
5133 W. Jason Dr.
Monee, IL 60449
Thanks, Pat
