  • June 14, 2025, 04:19:28 AM
Author Topic: Beech Staggerwing Profile Scale  (Read 2114 times)
Offline pat king
    • PDK LLC
« on: June 18, 2017, 08:24:35 AM »
This airplane is a Beech D-17S at 1 3/8” = 1’-0”. It has a 47 1/8” wingspan and 622 square inches of wing area. It is for 45 to 53 size engines. The CAD plans show all parts full size. The kit does not contain any control system hardware, a control hardware kit is available.  I will email a file of the 3 view used to design the kit to the buyer if they just ask.  The laser cut kits sell for $200.00 plus shipping for 4 pounds from zip 670449.
Staggerwing Control System
This system includes RSM 4" Carbon Fiber Bell Crank, Lead out wires, RSM Bellcrank Mount, 5 mm Carbon Fiber push rod tube, Right hand and left hand threaded push rod ends with Ball Links, #4 fender washers for the ball links, and 1/8”  Elevator Horn. The fender washers are larger than the balls in the ball links, they go between the ball and the bolt head. The link cannot get past the washer even if it comes off of the ball. The Push Rod System is infinitely adjustable. Just turn the carbon fiber rod left or right to increase or decrease the push rod length.  This is a top of the line control system. This system retails for $54.99, I will sell it for $45.00 if ordered with the kit. This is the control system shown on the plans.
Pat King
Monee, IL
AMA 168941
