  • June 14, 2025, 05:28:16 PM
Author Topic: Twin Ringmaster Kits  (Read 5192 times)
Offline pat king
    • PDK LLC
« on: November 29, 2011, 12:35:07 PM »
The drawings for the Twin Ringmaster  are complete except for showing a control system. The airplane is for .15 to .20 engines. The airplane has a 54 1/2" wingspan (12 1/2" C/L fuselage to C/L fuselage)with 508 square inches of wing area. The rib profile is Eppler 479 in the straight section and modified Eppler 479 in the tapered outer portions. The wing is built with a partially formed leading edge and a spar with spar caps. The horizontal tail surfaces have the same area ratio to the wing as the S1. The kits will be laser cut with landing gear wire, nylon straps for the landing gear and bellcrank . The airplane has an adjustable leadout guide and a weight box. The kit will not include any control system parts.
I will sell the first kits for $90.00 plus shipping and insurance.
I want to thank John  McCollum for his input and advice.
Thanks, Pat
This and the 1/2A size airplane will be known as: "Twin Ringmaster" and "Twin Baby Ringmaster". I am working on the "Ringmaster Twin" which will have one fuselage and twin engines in nacelles.
« Last Edit: December 09, 2011, 07:08:02 AM by pat king »
Pat King
Monee, IL
AMA 168941
Offline Dan Labine
Re: Twin Ringmaster Kits
« Reply #1 on: December 15, 2011, 05:31:29 PM »
Hi Pat.
Let me know when you have one available..
Dan
Dan
MAAC 14300
Offline Dan Labine
« Reply #2 on: August 05, 2012, 02:33:28 PM »
Hi Pat
Any update on the twin?
Dan
Dan
MAAC 14300
Offline pat king
    • PDK LLC
« Reply #3 on: August 05, 2012, 04:52:36 PM »
Dan,
I am selling the kits. Sorry I didn't let you know. I don't think I have a kit in stock right now. Let me know if you want one.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline Dan Labine
« Reply #4 on: August 13, 2012, 04:24:10 PM »
Hi Pat.
I sent you an email..
Dan
MAAC 14300
Offline Dan Labine
« Reply #5 on: October 16, 2012, 05:44:10 AM »
Hi Pat.
Kits arrived safely..thanks
Dan
Dan
MAAC 14300
