  • June 14, 2025, 01:55:23 AM
Author Topic: QUICKIE RAT II  (Read 4944 times)
Offline pat king
    • PDK LLC
QUICKIE RAT II
« on: December 31, 2016, 10:16:52 AM »
Here is a laser cut kit of Riley Wooten’s Quickie Rat II. The airplane has a 30” wingspan and 133 square inches of wing area. This airplane has not been kitted previously. Riley says that this is a better airplane than the original Quickie Rat. It is more stable on take-off.  The design has been revised to have a basswood leading edge. There is now a 1" strip of basswood for the leading edge.The kit does not contain a bellcrank, but contains all the wood and music wire. Brodak P222 is the right bellcrank for this kit. The plans are full size CAD plans with all parts shown full size. The kits sell for $63.00 plus Priority mail postage from 60449.
Thanks,  Pat
« Last Edit: January 01, 2017, 09:35:32 AM by pat king »
Pat King
Monee, IL
AMA 168941
Re: QUICKIE RAT II
« Reply #1 on: December 31, 2016, 10:48:40 AM »
blank
« Last Edit: March 06, 2022, 04:48:57 PM by Motorman »
Offline pat king
    • PDK LLC
Re: QUICKIE RAT II
« Reply #2 on: December 31, 2016, 12:32:36 PM »
The wing is .275" thick Balsa. The wing comes planned to .275 and the tips chamfered. The Quickie Rat wing is Balsa. The design could be changed to have a 1" basswood leading edge. The wing is not shaped. If I can get an order for 1000 kits I can afford the tooling to shape the wings.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: QUICKIE RAT II
« Reply #3 on: January 01, 2017, 12:42:03 PM »
The Airplane has been revised. See the original posting at the top.
Pat
Pat King
Monee, IL
AMA 168941
Re: QUICKIE RAT II
« Reply #4 on: January 03, 2017, 10:15:58 PM »
blank
« Last Edit: March 06, 2022, 04:48:38 PM by Motorman »
Offline pat king
    • PDK LLC
Re: QUICKIE RAT II
« Reply #5 on: January 04, 2017, 11:50:15 PM »
I'll take your word for that. I have never seen a Fox Bellcrank.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Re: QUICKIE RAT II
« Reply #6 on: January 05, 2017, 10:42:28 AM »
Brodak P222 is the 2" perfect bellcrank. I would recommend the 2" Fox bellcrank if your engine is at a power level higher than say a (factory stock) Fox 35.
Where are you getting your Fox bell cranks? ???
Offline Fredvon4
  • Central Texas
Re: QUICKIE RAT II
« Reply #7 on: January 05, 2017, 12:19:03 PM »
My understanding is Fox door shut now for 2 years and they do NOT have ANY remaining old stock of parts or products
SO I have same question every time someone advises a Fox item or to Call Sharron in Fort Smith to see...
I am sure there are still a bunch of NOS Fox stuff out there...I just don't know who has any of it
But I do know where the lion's share of Cox items are... but much of that is dwindling fast
Fred von Gortler IV
Offline Dane Martin
  • heli pilot BHOR
Re: QUICKIE RAT II
« Reply #8 on: January 05, 2017, 12:19:32 PM »
I am loving this kit, my question is... why the little bellcrank?  Could a three inch work since it's outside? I thought a racer would benefit from slower control
Offline pat king
    • PDK LLC
Re: QUICKIE RAT II
« Reply #9 on: January 05, 2017, 02:56:48 PM »
This one shows a 2" bellcrank because that is what the original used. A 3" could be used, the output arm would probably need to be cut down. These things do not need a lot of control throw, unless the circle just needs to be plowed!  LL~ LL~
Pat
Pat King
Monee, IL
AMA 168941
Offline Dane Martin
  • heli pilot BHOR
Re: QUICKIE RAT II
« Reply #10 on: January 07, 2017, 02:59:01 PM »
Pat
We fly off grass. Maybe a good mowing..... lol
