I have used denatured alcohol from Lowe's and 91% Isopropyl from the drug store. Both work fine in the finishing application but if you handle what's left in the cup after it hardens, you'll find it rubbery. Thinning epoxy with alcohol has an adverse effect on its strength and most epoxy manufacturers will back that up. The best thing is to heat the epoxy to thin it and make it flow, no loss of strength. Again, when we're talking finishing resins, I doubt you're giving up much.
