  • July 20, 2025, 11:30:21 AM
Author Topic: Zinc Stearate Weirdness  (Read 1552 times)
Online Motorman
« on: November 14, 2020, 07:56:50 PM »
blank
« Last Edit: August 19, 2021, 05:33:03 PM by Motorman »
Offline Kermit Payne
Re: Zinc Stearate Weirdness
« Reply #1 on: November 16, 2020, 06:32:51 AM »
I have been using corn starch instead of talcum powder for several years now, mixed with nitrate clear and nitrate thinner.  I like it much better and is easier to find than the unscented, un-oiled talc.  However, any leftover will gel at the bottom of the container after about 2 - 3 days.  I figure it's got to be lighter than finely ground rocks!!!
« Reply #2 on: November 17, 2020, 07:59:23 AM »
What's wrong with using primer? They all do!!!
I never mixed anything with clear dope, but a tad of color dope mixed could have some advantages. I see no need to use nitrate also. But that's me.
You don't even need clear dope on sheeted areas if you really want to get technical. There's other products which are equally as good and possibly better.
You can start applying color paint right over primer without having a base coat of paint which has nothing to do with your color scheme. I forget because I pay no attention to it, maybe called a "tracer" coat? I believe silver is used.
Many modelers have great proven paint systems, but many are, in some ways, different, but in some ways, just about the same.
I like the system I put together and it'll take some serious conversations before I entertain a different one. Unfortunately, and as usual, this topic, finishing, brings argumentation. Which accomplishes nothing.
