  • July 16, 2025, 08:15:05 AM
Author Topic: White Primer  (Read 1226 times)
Offline Tom Strom
White Primer
« on: March 18, 2012, 09:57:13 PM »
Where can I find a good white primer?  I have always used auto primer, two part, and only comes in grey.  Looking for two part white.
Tom
Offline Greg L Bahrman
Re: White Primer
« Reply #1 on: March 19, 2012, 09:29:21 AM »
Klass Kote Epoxy primer comes in white or gray.
http://www.klasskote.com/
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Re: White Primer
« Reply #2 on: March 19, 2012, 10:48:00 AM »
Dupont makes a two part white primer. Not inexpensive.
Charles
Re: White Primer
« Reply #3 on: March 19, 2012, 11:07:17 AM »
Duplicolor has a large spray can of white primer which works well.  It isn't a primer/filler like their gray, but it is a good, automotive grade, primer and not costly.
BIG Bear
RNMM/AMM
Offline Tom Strom
Re: White Primer
« Reply #4 on: March 19, 2012, 11:35:19 AM »
Thanks all.  The epoxy primer looks great.  I will give them a try, as well as trying to find the Dupont.
Tom
Re: White Primer
« Reply #5 on: March 19, 2012, 11:37:51 AM »
I'm sorry Tom, I missed the "two part" aspect somehow.....
BIG Bear
RNMM/AMM
Offline Tom Strom
Re: White Primer
« Reply #6 on: March 19, 2012, 03:28:21 PM »
Hey, it's OK Bill.  I tried the Duplicolor and had the paint peel off.  Don't know if I did something wrong, or what happened.  So I want to stick with the two part stuff.  Makes my life easier.
Tom
Re: White Primer
« Reply #7 on: March 19, 2012, 07:05:49 PM »
I can understand that!  No need to change when you have something that is working.
Offline Bryan Higgins
Re: White Primer
« Reply #8 on: May 23, 2012, 03:49:28 PM »
Tom
You can't beat this stuff if your going the silkspan and dope route.
It is at Brodaks and i use it all the time works great. Sands real nice
too.  It is a great undercoat for your bright colors like yellows and
reds.
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Re: White Primer
« Reply #9 on: May 23, 2012, 03:54:31 PM »
Hi again Tom
If your interested in somthing a little more aggressive try TPCglobal.
They have it all. This is where i buy some of my better paints and
airbrushes.  This place makes learning to paint a little easyer with
all there info and products. H^^
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
