Building Tips and technical articles. => Paint and finishing => Topic started by: adam collver on August 25, 2013, 10:57:24 AM
How much psi does a compresser have to have to spray dope?
Pressure is not normally the issue as most compressors go up to about 100 psi and most guns need only 35~50 psi at the inlet. Its more about the volume needed from the compressor/tank system to keep up with what your gun requires. For a full size gun I would suggest at least a 20 gallon tank. Detail guns would work OK with the smaller pancake type units used for pneumatic nail guns.
What gun do you have or looking at getting ? Check the manufactures specs on the gun for the CFM required and try to match that to the compressor's output. You can get by with a lower compressor CFM rating than the gun CFM with a larger tank volume.
