  • August 02, 2025, 03:42:02 PM
Author Topic: What exactly is "sanding sealer"?  (Read 1831 times)
Offline GonzoBonzo
  • GonzoBonzo
« on: December 04, 2012, 07:05:36 PM »
I am familiar with "balsa filler coat", but not so with sanding sealer.  What are the differences?
TIA
Gonzo
Gonzo
Re: What exactly is "sanding sealer"?
« Reply #1 on: December 04, 2012, 07:11:50 PM »
I've never heard of "balsa filler coat".  Sanding sealer is clear dope mixed with talcum powder (and maybe mumble-mumble-stearate); you use it as a primer to fill imperfections in the finish on your way to a 20-point finish.
Offline Mike Keville
« Reply #2 on: December 04, 2012, 07:19:21 PM »
"Balsa Filler Coat" was a product sold by Aero Gloss many years ago.  It was not a sanding sealer, per se, but more of a commercial blend of our homemade brew of clear dope and talcum powder.  Personally, I found it to be a waste of time and money.  Others' "mileage may vary".....
IMHO, the best actual Sanding Sealer for modeling use was the old Testors brand, but it was Nitrate.  Used it on a series of FF Gliders, 1950s-60.  Most newbies won't remember that stuff.
Offline GonzoBonzo
  • GonzoBonzo
« Reply #3 on: December 04, 2012, 07:23:41 PM »
Yes Mike, Pactra made both.  I'm curious about the differences.
Gonzo
« Reply #4 on: December 05, 2012, 10:25:05 AM »
The basic difference was filler coat had much more filling agent , and was thicker than sealer, the sealer coat had much less sealing or filling agent in it.
Offline GonzoBonzo
  • GonzoBonzo
« Reply #5 on: December 05, 2012, 12:51:01 PM »
Thanks Randy.
Gonzo
Offline Jim Thomerson
« Reply #6 on: December 05, 2012, 12:55:42 PM »
I read, in an old source about how to finish FF hand launch glider wings.  Put on a thin coat of clear dope, then put on thick Calamine Lotion.  let dry, sand smooth, leaving lotion only in cracks or grain, then  a couple more thin coats of dope.   S?P
« Reply #7 on: December 05, 2012, 08:30:14 PM »
Wow.  Never heard of that one.  Makes a certain amount of sense though...filling the grain and all.  Might cause a problem with warping since calamine lotion is water-based (?).  I would give it a try, except for the fact that at this age I'm well beyond the HLG days I once loved.
Of course there are always Catapault-Launched gliders.  May have to just check this out.
« Reply #8 on: December 05, 2012, 10:35:55 PM »
   Catapult is great!   There seems to be two common classes - one with hand-held catapults, the other with huge and powerful poles (with guy wires) and a MASSIVE rubber that looks like a Wakefield motor.
      I can still out-arm most of the locals but I prefer catapult. For the hand-held version, it's a very tricky optimization to decide the length of the rubber and how long your arm is. There's a maximum length requirement, but it's not necessarily the best choice since you want to be able to stretch it near max, and sometimes a shorter one is better. My best results were with wings of either 1/8 or even 3/32 and a span of about 16". That get's it right on up there and of course I have access to huge piles of <4 lb wood. I have also used 1/8 balsa fuselages with .003 carbon strips as reinforcement (which I noted all the local experts copied for the next year).
   But definitely plan on using a chase bike, or running a lot, because they are pretty potent and marginally too small to carry a DT.
« Reply #9 on: December 06, 2012, 08:21:23 AM »
Install one of the micro radios with rudder only.    LL~ LL~  I guess I was never a true free flight guy as I never doped any,  rubber power or glider.
