  • July 25, 2025, 09:39:48 PM
Author Topic: ultrakote tips  (Read 1823 times)
Offline scott matthews
ultrakote tips
« on: March 05, 2011, 06:50:21 PM »
Hello everybody,I'm back with a new question.I decided to go with ultrakote covering on my latest project . I have covered half the stabilizer with ultrakote with my iron set at 220 degrees per instructions. Film went down great on flat surfaces but on the edges that have different angles it is not looking to good.Do you guys kick the heat up for compound edges or do you do something different. My past experience with monokote is to crank up the heat to glue down and then burn your fingers with the heat gun to stretch the film around the bends. I plan on covering the wings tommorrow and I would like to know how you make a nice looking bend around the wing tip.I have also looked at the tips on hanger 9:s web site on how to use ultrakote.Should I increase the heat above 220 for compound curves per instructions to make this film more pliable.Thanks Scott
Re: ultrakote tips
« Reply #1 on: March 07, 2011, 09:28:39 AM »
Try cranking the heat up a little at a time.  Need to give yourself more material to pull on when pulling it around compound curves/surfaces.   I save the cut offs/scraps for paching and graphics.
Re: ultrakote tips
« Reply #2 on: March 07, 2011, 03:55:31 PM »
I have tried a few heat experiments to see that it does start to conform to compound angles around 300 degrees. I also tried to use the heat gun on a test piece to discover that chrome colored ultracoat turns a dull burnt look, so I"m assuming that using a heat gun on wing tips is out. The other lesson that is becoming obvious is that no matter how much you try to avoid small wrinkles in chrome coating its just going to happen I have noticed that I can limit some wrinkles by trimming the over hang into small ribbons and working with each piece individually.
Re: ultrakote tips
« Reply #3 on: March 07, 2011, 04:18:58 PM »
Some colors will change with heat, but usually go back to original color when cool.   And yes I do keep a single edge razor blade handing slicing the covering at the tips.  H^^
Offline dennis lipsett
Re: ultrakote tips
« Reply #4 on: March 09, 2011, 03:04:32 PM »
Chrome either Monokote or Ultrakote or any metallic covering is really tough to do well. For that reason it is usually not put on in large sheets. Too much heat usually distorts the outer finish. In Monokote you get an awful whitish staining that will not disappear when cool so you have to get rid of the piece. Ultrakote does similar when over heated.
I usually do not use a heat gun but use the iron and nibble at it when doing curves. just keep moving in small increments working it and getting it stuck down and it usually can be done without wrinkeling.
Offline bob branch
Re: ultrakote tips
« Reply #5 on: March 14, 2011, 09:14:22 AM »
300 degrees is what you need to do compound curves with Ultracote. It works well with a heat gun as well but you need to use the diffuser on the heat gun or it will burn. I included a detailed course on Ultracote application in the T-Rex build thread in the electric forum.
bob branch
Offline Jim Oliver
Re: ultrakote tips
« Reply #6 on: March 14, 2011, 10:42:54 AM »
Never used the chrome stuff, but with normal U.C. or M.C. I wear a leather drivers glove on the left hand and use the heat gun for wing tips.  I sometimes have to use sandbags (or a helper) to hold the wing or other object, to allow me to stretch the covering around compound curves.
Don't know the temp of the gun, but it's one of the old covering guns (T.F. maybe).  Amazing how much compound curve the covering will stretch over, with the heat-as-you-pull technique.
As usual, YMMV!!
Jim Oliver
AMA 18475
Re: ultrakote tips
« Reply #7 on: March 14, 2011, 04:01:47 PM »
Thanks guys for the tips they are much appreciated.Followed Bobs advise and turned the heat up to 300 to do the radius on my rudder and with some Patience and pulling noticed the ultracoat stretching to conform to the bend. Also noticed that you have to hold it in place for a short time to let it cool back to sticking temperature.Did a search for the T-Rex ultracoat covering article and found lots of info on building the plane but no article on covering can you give me a little more direction on this search to find the clip.Scott
Offline bob branch
Re: ultrakote tips
« Reply #8 on: March 14, 2011, 04:24:52 PM »
Scott
Its in the T-Rex build thread itself. Just go down til you get to the pics where I start covering it.  You are right, you want to hold it down to let it start to cool. The monocote glove is also handy. Its a lambswool covered glove. When you heat the film for shrinking you can massage it down onto the wood without sratching and it gives a very good finish. You can also use either the iron or the gun for covering compound curves. Just depends on what gives you best milage. Everyone's will differ.
bob branch
Re: ultrakote tips
« Reply #9 on: March 14, 2011, 06:54:13 PM »
Thanks Bob for an incredible article, lots of info to divulge I will be coming back to this article many more times for guidance.Great looking bird by the way you the man! Scott
Re: ultrakote tips
« Reply #10 on: March 23, 2011, 08:44:20 PM »
Randy's Ultracoat tip#1: The trashcan is in the corner.
