  • July 09, 2025, 07:23:33 AM
Author Topic: Two part clear in a spray can  (Read 1420 times)
« on: August 16, 2010, 06:00:00 PM »
Has any anyone tried this yet? b1 I saw this on a Bicycle forum I am on.
http://www.ketone.com/rm_aeromax_urethane_clearcoat.php
Ed :X
Offline Ward Van Duzer
Re: Two part clear in a spray can
« Reply #1 on: August 17, 2010, 01:38:28 PM »
$48.50 a can!
W.  ~^
« Reply #2 on: August 17, 2010, 01:52:03 PM »
I'll pass on that too. H^^
« Reply #3 on: August 17, 2010, 03:54:27 PM »
Yea, it appears from the ad that it mixes the paint and catalyst when you pull the red plug then you have to use the whole can (11.5oz). Says it is only good for a day or two after the plug is pulled.
And for 48.50 I can buy a quart of Omni and catalyst.
« Reply #4 on: August 17, 2010, 06:13:17 PM »
I wanted to know if any one had used it. Don't worry about the price,here is a add for $17. On the bike and motorcycle forums they are raving about it. On the motorcycle they mention it is great for the guy who doesn't have spray equipment.Bike forum said it looked like glass. Can is good for 24 hours after activation.Come on who will be first. ~^ If I can find it locally I will try it soon.
Ed #^ http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
Offline Jack Mulinix
  • AMA 917877
« Reply #5 on: August 18, 2010, 06:19:04 AM »
Have used it on two planes and a swamp buggy. Wesco paint supply has it on the shelf. 24 dollars a can. Thought it looked good. and fuel proof. I'll use again. spray max also has regular clear poly thats fuel proof and about 10 a can. and the red plug pushes in to pierce a bladder.
« Reply #6 on: September 29, 2010, 02:43:08 PM »
OK Jack, How many cans of 2 part urethane to finish a plane? What size planes? How many coats did it take to get the WODERFUL finish? $17.00 would seem a "bargain" if you can do an SV-11 with 1 can...
Eddie, have you tried it yet? Anybody?
W  y1
  • AMA 917877
« Reply #7 on: September 29, 2010, 07:34:33 PM »
Well, I did a Sig mustang and used 2 cans. Probably should have used 1. But you can see a shadow from stuff under it. Jack
