  • June 17, 2025, 11:33:07 AM
Author Topic: polyurithane??  (Read 1640 times)
Offline Bootlegger
polyurithane??
« on: February 14, 2018, 09:40:03 AM »
  Is polyurethane fuel resistant?  I am going to paint a wooden flight box and I want something that will at least resist fuel soaking.  Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Fredvon4
  • Central Texas
Re: polyurithane??
« Reply #1 on: February 14, 2018, 12:44:08 PM »
Gill I use MinWax water and oil based Polys for several things... I think it is fuel proof "enough" but only after some 10 or more days of curing
Unless you spill raw Nitro on the box it will be just fine as a finish
I also have pretty good luck with most Rustoleum type spray Enamels on fuselages and one of my flight boxes...same applies...loonger cure time needed---- seems to hold up well to my up to 25% nitro spills if wiped off
MinWax water based clear Poly seems to go right over the Rustoleum color coat just fine
Fred von Gortler IV
Re: polyurithane??
« Reply #2 on: February 14, 2018, 02:27:48 PM »
I used Varathane polyurethane color paint on combat planes long ago. Great finish and completely fuelproof, but it took a long time to dry.
Offline Istvan Travnik
Re: polyurithane??
« Reply #3 on: February 14, 2018, 05:40:19 PM »
Only one disadvantage I observed with Polyurethane: it can be yellowed by years. When basic color of your model is white, it can be disturbing.
It is up to your taste how to solve this problem: best is to choose yellow to basic. (Dark colors are not practical as a base.)
Offline Bootlegger
Re: polyurithane??
« Reply #4 on: February 26, 2018, 04:51:20 PM »
  Guy's I sure do thank all y'all for the help, got it painted and now drying, again thanks.. y1
Gil Causey
AMA# 6964
