  • June 18, 2025, 12:40:51 PM
Author Topic: Trophy Trainer Fuselage  (Read 1877 times)
« on: September 05, 2012, 12:05:41 PM »
HI All,
Aaron has a Trophy Trainer fuselage built.  1/4" core and 1/8th" siding.  It is ready for a finish.
It will be used in Profile at meets, possibly even Advanced in bad weather.
Bare balsa, how would YOU finish it?
Thanks!
BIG Bear
RNMM/AMM
Re: Trophy Trainer Fuselage
« Reply #1 on: September 05, 2012, 02:42:41 PM »
Depending on how I was finishing out the wings, I'd either do the Rustoleum "system" or good old dope & silkspan.
If I were putting film on the wings I'd go Minwax Polycrylic and silkspan as a base, with Polycrylic and talc for fill, then Rustoleum primer and Rustoleum Gloss Protective Enamel (then I'd spray Rustoleum Gloss Protective Enamel as trim on wings and fuse).
If I were doing any dope-based finish on the wings, then I'd go the traditional dope & silkspan route on the fuselage, so that everything would be 100% compatible.
But -- that's me.
« Reply #2 on: September 05, 2012, 04:11:25 PM »
Or you could do it they we used to. 1/2oz fiberglass and resin on the fuse, sand, prime with KlassKote primer and paint with Klasskote color the iron-on for the wings and flying surfaces. Worked well in the day (though we used Superpoxy).
« Reply #3 on: September 05, 2012, 04:27:53 PM »
How much weight do you add with the fiberglass & resin?  I've always shied away from that.
Offline Balsa Butcher
  • High Desert Flier
« Reply #4 on: September 05, 2012, 04:44:37 PM »
If it's 2 coats of Z-poxy (one to apply, second to fill) and Sig 1/2 ounce fiberglass weight build up is minimal because it doesn't take much expoxy to get a good bond or finish and you sand most of it off. Try it, you'll like it. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #5 on: September 06, 2012, 06:47:35 AM »
I've been using resin and cloth since the 80's right to this present day! Mentioned this many times on this Forum and SS.
I'll never stopped using it. Why change a winning game? That method is still popular with many modelers today.
Light? You can remove as much of it as you want with sandpaper, and if you use a quality resin, you don't have to blot the applied resin with toilet tissue, although that process eliminates some sanding.
I have resin on The New American, just to fill the wood grain before applying a few coats of dope before silking.
As far as primer and paint? I have a local body shop that will spray that stuff for me. I'm going to do a Thread on this. All I will do is the masking and make a few trips. One for the primer and one for each color.
I'm trying to keep my model building and finishing simple.
I should post the Avenger photo.  ;D
Charles
« Reply #6 on: September 06, 2012, 11:10:54 AM »
Just do't tell anyone that you let someone else spray your finish.   There goes appearance points to some people.
« Reply #7 on: September 06, 2012, 11:33:58 AM »
John,
It's not an issue because I'm not interested in appearance points.
Charles
Online Crist Rigotti
« Reply #8 on: September 06, 2012, 04:17:17 PM »
HI All,
Thanks!
BIG Bear
RNMM/AMM
Monokote and powered by electric!
« Reply #9 on: September 06, 2012, 05:03:57 PM »
Neat idea, Crist, but we aren't that far into electric yet.  And Aaron is painfully short of money right now.  He has a few OS .46LA to choose from, or a few ST .46.  At least they are paid for! LOL!!
BIG Bear
RNMM/AMM
« Reply #10 on: September 06, 2012, 06:59:53 PM »
BIG Bear
RNMM/AMM
Paid for is good!
Offline Gary Anderson
« Reply #11 on: September 08, 2012, 09:57:26 PM »
BIG Bear
RNMM/AMM
Hi Bill,
Both engine work very well, better than most. My LA 46 is several years old and still runs like a champ. The ST 46 is a great motor but I don't believe they hold up as well as the OS 46. Have fun!!
God Bless
Gary
Gary Anderson
