I needed to remove old waterslide decals on an older Sterling Mustang, so I tried what I have around the shop.
A Fine 3M pad eventually took them off the balsa fuselage but barely touched the stars on the iron-on covered wing, and I began to cut through the covering.
Cello tape pulled up minute particles - don't think I'd live long enough.
I tried rubbing a couple minutes with a cotton swab: 70% iso alcohol, acetone, Goo Gone, lighter fluid and Microscale Micro Sol - not even discoloration on the swabs.
Possibly if left long enough, they might show some results, but I'm impatient.
I've read that Microscale Solva Set will work, but don't have any.
Swabbed on and left to set:
Klean Strip gel paint remover softened the white, not the colors, before it seemed to be attacking the film, so I discontinued.
Brake fluid dissolved white and red after 3-ish minutes, the blue took 20-30 mins and gentle rubbing with a craft stick.
Wiping smeared residue all over but alcohol easily removed it.
Success!
But I would not have believed anything so seemingly fragile could be such a PITA to remove.
Anyone have an easier way?
Terry
