  • July 12, 2025, 11:26:38 PM
Author Topic: Tinting Nitrate Clear / Randy's Filler Mix  (Read 1887 times)
Offline Joe Rice
« on: November 22, 2011, 06:23:56 AM »
I am using Nitrate Clear for the substrate work on a project and plan to use Randy's filler in the nitrate for the next step.  Randy suggests tinting with black dope, but I cannot mix black butyrate with the nitrate clear.  Are there any options for tinting nitrate so I can see my work  S?P
Joe
Joe Rice
AMA 740106
Offline Bootlegger
Re: Tinting Nitrate Clear / Randy's Filler Mix
« Reply #1 on: November 22, 2011, 07:08:52 AM »
  Put a small amount (1 oz) in a container and try some Rit dye that is powdered mixed into it, by using a small amount you don't mess up a larger portion.
  You might try the same method in thinner, then mix that into the dope...
   Good luck, and let us know how it worked, also go to an automotive paint store that mixes paint and have them put some black toner in the dope.. D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Joe Rice
« Reply #2 on: November 22, 2011, 07:20:11 AM »
Gil, Thanks for the tips  y1  I will try both methods and post the results....
Joe
Joe Rice
AMA 740106
« Reply #3 on: November 22, 2011, 02:22:27 PM »
Joe,
Nice looking model!
What is it covered with?
CB
« Reply #4 on: November 22, 2011, 02:37:35 PM »
Just from experience, the best tint I've seen for dope is House of Kolor's Kandy Koncentrates. Pretty much any color you want, don't fade in the sun and is a killer look. My buddy Pete Peterson did an article in Stunt News about this recently. Weirdly, he uses Lime Gold to tint butyrate and it comes out a nice yellow over balsa. What's underneath makes a big difference in the color of tint you choose.
Offline Joe Rice
« Reply #5 on: November 22, 2011, 03:27:08 PM »
Joe,
Nice looking model!
CB
CB... Thanks for the compliment. It is Fancherized Twister. The wing is covered with Polyspan.  Flaps, stab, elevator are .2 oz. carbon matt from Randy. Fuse is silkspan.  Landing gear from a defunct Cardinal ARF, pants from a Vector.  DS40 Classic power.  Debating on using color dope, or auto base coat/clear coat at this point.
Joe
Joe Rice
AMA 740106
« Reply #6 on: November 23, 2011, 06:00:30 AM »
Ty's india ink solution works really well.  I've also tinted epoxy with it for other purposes.
« Reply #7 on: November 23, 2011, 11:44:24 AM »
I had a slight problem once when I ran of Randolph's tinted (blue) non tautening Nitrate in the middle of a project.  A bottle of blue ink from Staples worked perfectly.  The black india ink will work perfectly, also.
Big Bear
Offline don Burke
« Reply #8 on: November 23, 2011, 05:12:57 PM »
Disolve the powder in a little thinner before mixing, prevents little lumps from forming and mixes easier.
don Burke AMA 843
Menifee, CA
« Reply #9 on: November 23, 2011, 10:17:00 PM »
Would there be a problem with dye/ink leeching out of the dope/talc when further coats of dope were applied? Seems like a good time to change to butyrate, to me. Then, you could just add a bit of leftover pigmented dope to your clear/talc mix.  :-\ Steve
« Reply #10 on: November 25, 2011, 12:22:42 PM »
Hi Steve,
I have never experienced leeching of the ink from further coats.  Butyrate goes over Nitrate exceptionally well (as does all the other "paints" I have finished with so far).  The ink becomes part of the nitrate as does any other "toner" or pigment.
Big Bear
Offline Joe Rice
« Reply #11 on: November 26, 2011, 02:56:29 PM »
OK... I got some black 1k base coat toner from the local auto body supply store and added more than a few drops to a 1 ounce sample of nitrate clear / nitrate thinner with Randy's aero 1 filler.  It worked just fine... totally suspended and stayed that way.    y1
Joe
Joe Rice
AMA 740106
