  • July 20, 2025, 02:09:24 AM
Author Topic: These products are compatible  (Read 2007 times)
Offline bill bischoff
« on: June 16, 2018, 11:34:29 AM »
Here is my most recent finishing sequence. I am happy to report that all the products worked well together, and particularly that the clear didn't affect the lacquer, decals, or ink lines.
Base: 3/4 oz glass cloth and finishing epoxy over wood, Super-Fil fillets
Primer: NAPA DC540 aerosol gray primer
Color: Duplicolor Perfect Match aerosol acrylic lacquer
Trim: airbrushed dope for canopy, water slide decals from Bill Calkins, IdentiPen permanent marker for ink lines
Clear top coat: KlassKote 2 part epoxy paint, airbrushed
This was my first time with the Duplicolor lacquer. It went on beautifully, but blushed a bit due to the heat and humidity. Burnishing lightly with 0000 steel wool took care of it. It was also my first time to do ink lines.
Offline Bootlegger
Re: These products are compatible
« Reply #1 on: June 16, 2018, 12:04:02 PM »
  Got any pictures?  Sure would like to see some... #^ #^
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: June 16, 2018, 01:02:11 PM »
What happens when it sits outside on a sunny day?  I had trouble with dark acrylic lacquer colors under a catalyzed polyurethane topcoat.
« Reply #3 on: June 16, 2018, 01:36:09 PM »
Howard, it's way to soon to tell.
Offline Charles Meeks
« Reply #4 on: June 24, 2018, 05:16:02 AM »
That is really nice Bill!
Charles Meeks
Abita Springs, LA
Baton Rouge Bi-Liners
AMA # 988201
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: July 03, 2018, 11:51:37 PM »
Nice job as usual  Bill, and thanks for the paint sequence/recipe. I'll use it on my next racer. y1
Pete Cunha
Sacramento CA.
AMA 57499
