  • July 30, 2025, 07:59:22 AM
Author Topic: Test pieces.  (Read 43466 times)
Offline Perry Rose
Test pieces.
« on: May 08, 2024, 09:10:54 AM »
I have used bare wood, the side of a gallon can, sheet nylon, plastic masking sheet and now the side of a Kleenex box as the base for testing paint compatibility. In every case the results were perfect finding the paints to be compatible.  But in every case when I painted the plane the results were disastrous. How should I be conducting the paint tests so I can be sure they won't react? Wait times between coats had no effect on the outcome.
Offline Lauri Malila
Re: Test pieces.
« Reply #1 on: May 08, 2024, 02:01:40 PM »
Well, you should prepare test piece in a same way than the final workpiece. Meaning, a piece of balsa with the covering & sealing/priming of your choice. L
« Last Edit: May 08, 2024, 02:30:22 PM by Lauri Malila »
