  • July 20, 2025, 11:24:02 AM
Author Topic: Tautening or non tautening?  (Read 1107 times)
Offline Mike Griffin
« on: November 21, 2019, 01:27:11 PM »
When covering with silkspan or polyspan on built up flaps, do you use tautening or non tautening dope?  I was worried about tautening dope causing the flap to warp.
Re: Tautening or non tautening?
« Reply #1 on: November 21, 2019, 04:12:57 PM »
A trick that I stumbled on when I ran out of tauting dope and was too impatient to wait on an order using polyspan was to dope it with the non-tauting then hit it with a heat gun while it was still plastic.  After two coats like this it was drum tight and has stayed that way for a year.  The good (and bad) thing about polyspan is that it will keep shrinking if you keep heating it - right up to the point it melts.  Once those tauting coats dried, the non-tauting did not loosen it.
« Reply #2 on: November 25, 2019, 02:23:53 PM »
Thank you for the help.
