CLICK HERE--><--CLICK HERE
Removing overspray from automotive clear
Started by Brett Buck, June 21, 2026, 05:02:44 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Brett Buck
    I made some of my pre-NATs touchups/fixes this week. As usual there was some very light overspray left on some of the surfaces. I had assumed I could use various solvents to remove this (two-part epoxy paint, K&B Superpoxy, in this case) since the automotive clear can tolerate some of that. But, when I bought my last van, it had apparently been left outside the paint shop, and also had pretty significant overspray. I tested a few methods to try to remove it, and nothing worked aside from acetone. Not wanting to take after my brand new yesterday van with a reasonable paint stripper, I instead tried clay bar. This is normally used on car paint to remove all the little particles that imbed themselves, so you can then wax it cleanly. It's kind of a miracle, it is super-sticky clay with some sort of lube - instant detailer, etc. All you do is spray on the detailer, gently glide the clay over it, and it pulls all these little zits out. On the van, it worked great to remove the overspray, as well.
    So, I tried it on the airplane, and literally took about 30 seconds to remove all the overspray while leaving *no damage* or scratches to the paint. This was over about half of each wing, and the entire tail, and some bits of the fuselage. So, while I can't tell you how it works on dope or other finishes, it works incredibly well to remove light/mist type overspray from car clear or two-part epoxy with what I think is *no chance of damage*.
 I have used Mother's "California Gold" clay bar kit on cars for years, this is my first time on an airplane. If you get overspray,  give it a try.
Like Like x 1 View List
Good stuff Brett! Do you think this would work with some specs of dirt in the clear? Or the old fashioned wet sanding will have to go with it?
Brett Buck
Quote from: Matt Colan on June 21, 2026, 06:49:16 PMGood stuff Brett! Do you think this would work with some specs of dirt in the clear? Or the old fashioned wet sanding will have to go with it?
   If it was actually encapsulated, probably not, but if it is just stuck on the surface a little, maybe. As far as I can tell, it is about as safe as it gets, and it much less invasive than sanding it. Worth a try.
doug coursey
IT WORKS REALLY WELL ON GLASS TOO LIKE THE WINDSHIELD...MAKES IE EASIER TO CLEAN
AMA 21449
Kevin K
