  • July 31, 2025, 05:58:25 AM
Author Topic: Starved horse leading edge sheeting  (Read 8124 times)
Offline David Ebers
« on: November 30, 2023, 07:12:45 AM »
All the LE sheeting has developed a starved horse look. I have no idea when, how or why. I've been on and off this build.
The plane is and RSM Naughty Girl. LE sheeting glued with titebond. 3-4 coats of 50/50 non tautening nitrate, polyspan attached with same. 3 more coats of the 50/50. I set it aside for a month or so before going back to it.
My questions are what caused this and can it be fixed?
David
Re: Starved horse leading edge sheeting
« Reply #1 on: November 30, 2023, 08:36:19 AM »
Your only hope is the polyspan.  Heat *may* soften the tightbond and shrink the polyspan to lift it some...or not.  Next time feed the horse.  LL~
ken
Offline 944_Jim
« Reply #2 on: November 30, 2023, 10:58:27 AM »
I fly small and I use DocSpan..so this may not mean much on the big stuff typically seen here.
How much swag between the ribs have you got?
I'm guessing the sheeted edge sits across ribs in open space just below the crown of the rib, without closing in the backside of the LE?
I get the same thing with tissued LEs and recognize as the covering is pulling across the wing, it is also pulling fore/aft (thus down) between the ribs..from LE to TE. That fore/aft part is doing a fine job of straightening out/pulling down...more/better than the straightening out/pulling across from rib to rib.
I saw this happen to an extreme on a kit I really wanted to finish, so I laid into it with fresh, really cut thin nitrate dope and a hair drier trying to shrink between the ribs more. Now I have a yellow non-flying Pringle.
For my little guys, I accept it and move on. My next few small planes will have one or two small stringers across the ribs from the rib's high point or spar to LE just so shrink going side-to side-will have a better chance of beating fore-and-aft shrink. I suspect it will be minimized for a while yet never beaten for long.
This may not be the lightest way to go and it certainly isn't a permanent solution (unless you close in or brace an open-at-back LE)...cut the covering away from the open space and recover dry, skip shrinking for shrinking's sake, and repaint. Take care to avoid significant shrinkage, which may entail including a flex agent.
Oh did I mention I build entirely too heavy?
« Last Edit: December 01, 2023, 12:04:20 PM by 944_Jim »
« Reply #3 on: December 01, 2023, 11:58:05 AM »
I have that on the one I'm building now, with similar construction.  I'm suspecting the titebond.
Nothing to do about it now -- name the plane FIFI* and carry on.
* F--- it, fly it.
Offline David Ebers
« Reply #4 on: December 01, 2023, 02:44:26 PM »
It may be the titebond with the very lite, 6#, a grain balsa in the RSM kit. I build all my wings with LE sheeting the same way. This is the first time this has happened. The others were also covered with kote. Most kits I've built have heavier balsa. Maybe thin the titebond next time?
I had the bright idea to brush straight thinner,  Randoloh, on the LE sheeting. The balsa did spring back some.  I brushed another coat and will check it tomorrow.
My wife did not care for the name of the plane. I added a balsa teipler and sheeted the wing tips Doug Moon style. Told the wife I'll rename the plane. Haven't told her the new name will be Reformed Naughty Girl..........
« Reply #5 on: December 01, 2023, 05:23:57 PM »
That balsa should have been sent to me. As for reforming naughty girls, my only contribution would be creating a supply of them from nice girls.
« Reply #6 on: December 01, 2023, 06:35:19 PM »
Titebond will soften somewhere between 150 and 200 depending on the source.  If you were to use a Monokote iron and run it over the ribs slowly it might soften the titebond and shrink the Polyspan.  If you have the polyspan grain spanwise it would pull the balsa up.  This is 100% theory.  I don't use anything but CA and Epoxy on sheeting and I don't use light(<5) or heavy(>7) wood either.
You can always use panel lines on the highpoints to make the horse look well fed.
ken
« Last Edit: December 03, 2023, 12:22:56 PM by Ken Culbertson »
Offline 944_Jim
« Reply #7 on: December 01, 2023, 11:32:54 PM »
Obviously I don't know the plane, Mr. David,
Is this a D-tube LE, or open at the back? I'm curious.
Offline David Ebers
« Reply #8 on: December 02, 2023, 01:36:22 PM »
It's what I'd call a C-tube. No shear webs.
The thinner trick didn't work. Guess I'm stuck. It's not as bad as a Twister wing with no half ribs covered with kote. I'll tell the appearance judges that the LE dips are areo enhancements similar to VGs.
Offline Jim Svitko
« Reply #9 on: December 03, 2023, 10:21:34 AM »
When you attached the sheeting, did you wet it first to help it bend, then glued it down while still wet?  If so, then this might contribute to the problem.
The wood will expand when wet.  If you glue it down in that condition, it will be locked in place, and when the wood dries, it will want to shrink back to original dimensions.  It can't do that easily since it is glued down.  So, it shrinks back as best it can and gives that hollow appearance.
If you wet it, hold it in place with tape or Ace bandage to shape it to contour and let it dry completely before gluing it down.
Maybe heavier wood, such as 7lb. or 8lb., will have less tendency to produce the problem you have.
« Reply #10 on: December 03, 2023, 02:20:09 PM »
Yep. I mold the wet LE sheet over a solid form by Bob Hunt’s method, then stick the shell onto the ribs after it dries. This probably helps, but I have been sneaking extra ribs into the wing after it’s built.
Offline David Ebers
« Reply #11 on: December 04, 2023, 07:58:47 PM »
I do wet the sheeting but don't glue it down when wet. I glue the sheeting to the LE. When dry, I dampen the top and bottom of the sheeting clip on enough clothes pins for the sheeting to touch the spar. This sets at least overnight and sometimes longer.
When I attached the polyspan I doped down it the sheeted areas then shrunk it down with heat gun when dry.
Offline Jim Svitko
« Reply #12 on: December 04, 2023, 09:37:52 PM »
When I use polyspan, I attach it to the wood only around the edges, using clear dope.  I let that dry then I shrink it with the Monokote iron.
Maybe doping the polyspan down to all the sheeted areas before shrinking it would cause your problem.  If the polyspan is stuck to the sheeting, then you shrink the polyspan, the shrinking of the polyspan might take the wood with it, if you know what I mean.
Offline David Ebers
« Reply #13 on: December 05, 2023, 12:27:08 AM »
Jim
That makes sense.......now. I
The polyspan would move across sheeting when shrunk if not attached to it.
