  • June 17, 2025, 01:47:31 PM
Author Topic: Brodak Kolar Kote?  (Read 2910 times)
Offline James Holford
Brodak Kolar Kote?
« on: December 31, 2016, 10:07:44 AM »
Anyone ever use this stuff? Any good? They have a few colors that's buy 1 get 1 free.. if is worth a damn I'll get a couple rolls.
Monokote and others alike in my area are nearly $20 a roll :0
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: Brodak Kolar Kote?
« Reply #1 on: December 31, 2016, 11:52:40 AM »
I bought several rolls of it one year to use on the Brodak Original Magician with a Brodak .25.   The rolls were Red, White and Blue.   The Red and blue were okay but the White was cr**.  It is the one iron on covering I not use any more.  The main problem was getting the backing off of them, all three colors.No I did not bug John Brodak about it as I know he would sned more of the stuff.  My experience.  Keep an eye out for the finishing on my new plane. H^^
Re:
« Reply #2 on: December 31, 2016, 12:00:14 PM »
I wonder if the Olive Drab is decent... hmm
Jamie Holford
Lafayette, La
AMA #1126767
Offline Russell
  • ACE
« Reply #3 on: January 16, 2017, 06:09:11 AM »
I bought one roll of yellow to try last year. Getting the backing off is next to impossible. I'll keep using MonoKote.
Sounds like it's on sale for a reason because nobody wants it.
Offline DanielGelinas
« Reply #4 on: January 16, 2017, 10:52:57 AM »
Just curious because i never had that problem with the white or coloured film i had from Brodaks...
Did you use the two tape method to try and separate the backing?
Also, i remember reading on the forum that some covering sold by Brodak does NOT have any backing...
Dan
« Reply #5 on: January 16, 2017, 12:56:59 PM »
I used the tape method that worked sometimes, but the one color the backing would come of in strips.
Offline Fredvon4
  • Central Texas
« Reply #6 on: January 16, 2017, 01:26:58 PM »
Just Covered a foam wing RST with (always on sale) Brodak Kolar Kote.. this time some purple... OK ...but I prefer other stuff better
I highly recommend staying away from the Brodak Kolar Kote "Black" as the glue/color does NOT stay stuck to the plastic and makes a grand mess!!!!
Fred von Gortler IV
Offline rich gorrill
« Reply #7 on: January 16, 2017, 02:13:29 PM »
I have used Brodak covering a few times. Mostly good results. Stay away from purple, when it shrinks it leaves a glue line. Had no trouble with blue or red. All backing came off easily.
Rich
« Reply #8 on: January 16, 2017, 02:16:01 PM »
As an add on, Ultracote is the easiest covering I have used. Two temps, one for gluing down and a higher temp for shrinking. If you check the bay you can get some good deals on it.
« Reply #9 on: January 16, 2017, 09:53:49 PM »
blank
« Last Edit: March 06, 2022, 04:26:03 PM by Motorman »
