  • July 05, 2025, 12:17:26 AM
Author Topic: Spray Paint  (Read 11328 times)
Offline Mike Griffin
Spray Paint
« on: July 08, 2022, 11:51:43 AM »
What brands of spray paint (ie Rustoluem,  Krylon, etc,) have been found to go over nitrate or butyrate dope without an adverse reaction?  I tried Rustoleum over dope once and got a really bad orange peel effect.
Thank you
Mike,.
Re: Spray Paint
« Reply #1 on: July 08, 2022, 06:23:37 PM »
Hi Mike, I am a huge Krylon fan as long as I intend to cover it with a clear fuel proofer.  Their color selections are really neat.
Re: Spray Paint
« Reply #2 on: July 08, 2022, 07:16:21 PM »
Mike,
I have used Rustoleum over dope with no problems. Most important thing was to apply thin coats. When I have had problems it was applied to thick and it knuckled. Best thing to do is sand the surface with 400 and wipe it down with degreaser, then spray light coats, watch the time between coats.
Best,   DennisT
Re: Spray Paint
« Reply #3 on: July 08, 2022, 07:38:47 PM »
Mike,
Best,   DennisT
Thank you Dennis.
Re: Spray Paint
« Reply #4 on: July 08, 2022, 07:39:55 PM »
Thank you Will.  I like the Krylon colors as well.  Just wanted to make sure you could spray it over Nitrate or Butyrate.
Offline Shorts,David
Re: Spray Paint
« Reply #5 on: July 09, 2022, 12:37:52 AM »
I recently used nitrate with silkspan. Then used Rust-Oleum sandable auto primer. This is the best primer I've used. Then used Rust-Oleum color. Only about four flights so far but zero ill effects. My next model will likely use the Rust-Oleum auto primer and then go back to butyrate because I've got all the cool colors already.
Offline Jim Hoffman
Re: Spray Paint
« Reply #6 on: July 09, 2022, 09:34:36 AM »
Beware, the sandable rattle can primers I have used do a great job of filling the last bits of grain, but are VERY heavy. I sand most of it off
Offline Jim Morris
Re: Spray Paint
« Reply #7 on: July 17, 2022, 06:58:37 PM »
This is of intrest to me. What clear do you use over krylon?
Re: Spray Paint
« Reply #8 on: July 17, 2022, 07:56:20 PM »
I have used nothing but Nason 2K for the past ten years or so.  Yes, it can be heavy if you get carried away, but with careful application and good sanding and buffing it is incredible.  (I also use it for the finishes on my custom guitars and basses.)
Offline Dwayne Donnelly
Re: Spray Paint
« Reply #9 on: July 19, 2022, 01:18:46 PM »
My latest two, both are Tremclad rust paint over dope.
Re: Spray Paint
« Reply #10 on: November 08, 2022, 07:50:27 AM »
Dwayne,
Is the Tremclad rust paint fuel proof? Did you clear over it - what kind of clear?
Best,   DennisT
Re: Spray Paint
« Reply #11 on: March 15, 2025, 06:22:47 AM »
Dwayne,
Best,   DennisT
Sorry I just saw your reply, there's no clearcoat but I did let it dry for about a month and it's very fuel resistant.
Re: Spray Paint
« Reply #12 on: March 15, 2025, 05:55:21 PM »
You can get a really bad orange peel effect any time you use Rustolium if you apply it out side of the instruction parameters. Not saying that's what happened but, I know that paint is very finicky.
MM :)
Online Mike Quinn
Re: Spray Paint
« Reply #13 on: June 25, 2025, 03:18:04 PM »
Hey Dwayne
I’m finally about to finish my Challenger I started 5 yrs ago.  Oracover, and Klasskote finish.  Same scheme as on front of Dick Sarpolus control line book.  Same same as yours 😀.  How did yours come out.  How much does it weigh?
Cheers.  Mike
