  • August 02, 2025, 05:57:23 AM
Author Topic: Spray or brush on filler?  (Read 4346 times)
Offline Mike Mulligan
    • Mulligan Racing Development
« on: January 15, 2016, 03:15:13 PM »
What are your preferences regarding filler application? I'm assuming that since most of it is going to be sanded off there really would't be much of a practical difference, but my assumptions are often wrong (imagine that...). Maybe skip the traditional filler and go straight to primer? This is my first time using carbon, and it seems to be much smoother that silkspan at this stage, though Phil Granderson's method uses filler over carbon...
I'm looking to bump up my finishes, so any thoughts, opinions, ideas or admonishments would be most welcome!
Thanks!
Mike Mulligan
AMA 789641
www.Mulliganracing.com Mike@Mulliganracing.com
Re: Spray or brush on filler?
« Reply #1 on: January 15, 2016, 08:04:27 PM »
Mike I've always brushed on filler since it needs to be pretty thick and certainly won't spray from my airbrush.  (All I use).  The dope has to be water-thin to come out and I even struggle with metallic colors through the airbrush. I mix my filler sort of thick and brush it.  You are going to sand most all of it away.  I find if the powder is mixed in well thinned dope it's easier to sand away than using full strength dope.  I've never used any 'primer'. Just wet sand the filler coat down glass smooth and shoot on color.  I'm not really too sure what primer is doing here.  That's fairly new in dope finishes.  Other than the color (which can be added to the filler mixture) it seems almost a repeat of the filler coat process to me.  Sometimes I'll spray on a couple clear coats over the filler then wet sand again to fill any porosity that is still there before color.  For the best finish you'd spray on a light coat of silver or light gray to highlight any bad spots.  These I fix with automotive spot putty and re-sand.
« Reply #2 on: January 17, 2016, 10:31:17 PM »
I've done it both ways. I have an auto primer gun (cheap Harbor Freight job) and it works pretty well. I don't see an advantage either way except maybe a little easier to sand the spray on as there are no brush ridges to sand down.
« Reply #3 on: January 18, 2016, 01:13:11 PM »
The vast bulk of my experience is with cars, and spraying has always been the best -- how much good the coat does is determined by the lowest spots, how much work you have to do is determined by the highest spots, and that difference is smaller with sprayed than it is with brushed.  AFAIK that translates over to models.
When I do brush it on I try to run the strokes crossways as much as possible (and I always do more than one coat before sanding) -- this seems to reduce the distance between high and low spots.
« Reply #4 on: January 19, 2016, 11:49:04 AM »
words have meanings,,
surfacer= material typically sprayed on to reduce the magnitude of surface imperfections,, ( in our case to fill wood grain and such)
primer = typically sued to denote a material which is primarily used to promote adhesion between dissimilar materials,, ( balsa and silkspan)
sealer = a material that isolates the top coats from the bottom coats, intercoat barrier, in other words, keeps the surfacer from interacting with the base coats and causing them to swell up, or in my case, I use a catalized sealer to prevent the solvents in my color coats from infusing into the carefully sanded Primer coats and causing them to swell ( then shrink) leaving unpleasant grain showing through
so, filler, is surfacer,, and yes, it fills low spots,  the depth or surface area of those imperfections is what causes weight gain,, some cannot be avoided, like the grain in the wood, some can be avoided, like wavy sheeting, poor sanding of the balsa, or bad fit joints,, the "filler" or surfacer can be what is commonly called primer, ( normally grey with talc added like Kondar DZ-3) or it can be clear dope with talk or Zinc Stearate added, or it can be just plane old clear dope,, if its filling voids or imperfections it is surfacer
if you are putting a barrier coat on top of the surfacer, then its a sealer no matter what material it is,, some materials are obviouslyh better suited to this task than others,,
This is not unlike the ongoing debate about "power": and the misuse of the term or I should say, the misuse of its definition,,,
that said, in almost all cases, if you can spray it on, you will get less shrinkage, less dry time, and less added weight ( assuming you sand properly) when compared to brushing it on.
the One caveat to this, when you are building up the primer on bare wood,, ( the clear you put on before silkspan or carbon) Dope is such a low solids material, you would greatly add time to the project to spray these on , I maintain you will ultimately get a lighter better finish than brushing it
Now before anyone attacks this statement, YES you can get a spectacular finish using proper brushing technique,, in fact I personally brush on a lot of my build up layers of dope,, but,, BUT< if you sprayed it all, you would have less dry time, and less sanding ultimately,,
Offline Fredvon4
  • Central Texas
« Reply #5 on: January 19, 2016, 12:48:43 PM »
To add to Marks idea is the necessity to understand the viscosity of the medium being sprayed and using the correct gun with the correct needle size and the correct pressure....all attainable with the low cost harbor freight type finishing guns and air brushes
Just simply thinning out the filler coat to a spraying viscosity might not get you the filler build up needed in one or two coats to fill the voids....
BUT if you like a heavy mix of zink, talc, cornstarch, or even micro balloons to fill the grain or weave--- this is doable with a lager then normal needle.
I bought enough (6 on sale with coupon) cheap 4oz HF spray guns and took two and ground down the needle and opened the nozzle quite a bit to spray thicker viscosity filler coats----NO they do not spray a good enough finish pattern for color or final clear coats, but they do put a lot of the filler on and a lot faster than I can brush it on...and a faster to dry so I can sand most of it back off sooner and repeat if necessary
Fred von Gortler IV
Offline Mike Haverly
« Reply #6 on: January 19, 2016, 04:19:54 PM »
Mark, thank you for addressing one of my pet peeves, especially primer and surfacing.  You know, or at least I think you know that I break a lot of rules when it comes to painting in general, but substrate prep and adhesion doesn't get by me.
I'm in the process of finishing up a project now where I used no primer and my filler coats were all clear dope.  Voids were handled with clear dope and zinc stearate applied with an airbrush.  So I guess the answer is yes, in some cases a voids, or dents and other imperfections can be dealt with by spraying.
Actually, Robert covered this pretty well, I thought, in his video using his Napa spray stuff.  It builds quickly and sands easily.  A little pricey for my tastes and is impractical for a lot of my work.
I wish more your wisdom would be heeded on this forum.
« Reply #7 on: January 19, 2016, 05:51:48 PM »
To answer a question up-thread. I use a cheap Harbor Freight gun for primer (or surfacer as Mark notes). It's 2.0mm needle and can handle pretty thick material. I use a cheap gun because surfacer or primer tends to be very hard on guns and they don't tend to last all that long.
« Reply #8 on: January 19, 2016, 08:18:02 PM »
There's got to be a compromise here someplace!  I think I'll use a roller next time.
« Reply #9 on: January 19, 2016, 09:19:25 PM »
You can do it either way.  I have the same gun as Randy, for the same reason.  Look at Phil's process, he sprays with talc infected dope, tinted with black.  Or at least he did at one time, things change from time to time.  Spraying is fine, especially for large areas, you just need the correct equipment.  I prefer zinc stearate.  You still need to go back and touch up the inevitable low spots.
A roller!! Now there is compromise! y1
« Reply #10 on: January 19, 2016, 09:25:56 PM »
Westcott, of all people,, just go back to your whisk broom to apply primer,, lol
as always, ( and you do the same thing in your field of expertise) I always default to the CORRECT answer, there is always an alternative, but ya takes your chances
« Reply #11 on: January 19, 2016, 10:32:15 PM »
I've never felt it was that big an issue. But as Mark notes, spraying tends to be lighter. More or less.
Offline Will Davis
« Reply #12 on: January 21, 2016, 06:51:23 PM »
sealer = a material that isolates the top coats from the bottom coats, intercoat barrier, in other words, keeps the surfacer from interacting with the base coats and causing them to swell up, or in my case, I use a catalized sealer to prevent the solvents in my color coats from infusing into the carefully sanded Primer coats and causing them to swell ( then shrink) leaving unpleasant grain showing so, filler, is surfacer,, and yes, it fills low spots,  the depth or surface area of those imperfections is what causes weight gain,, some cannot be avoided, like the grain in the wood, some can be avoided, like wavy sheeting, poor sanding of the balsa, or bad fit joints,, the "filler" or surfacer can be what is commonly called primer, ( normally grey with talc added like Kondar DZ-3) or it can be clear dope with talk or Zinc Stearate added, or it can be just plane old clear dope,, if its filling voids or imperfections it is surfacer
One of the best explanations of finish layers since college, thanks for posting ,
Will Davis
"Carolina Gang"
« Reply #13 on: January 21, 2016, 08:26:59 PM »
Glad to see it well recieved, thanks for the feedback
« Reply #14 on: February 01, 2016, 11:28:32 AM »
I'm constantly amazed at the depth of knowledge on this forum. I can't build as many airplanes as it would take to try everyone's individual methods, but I wish I could!
I've got the bird in question sanded and ready for filler and I think I'm going to brush on dope with zinc stearate this time. I know it probably means a bit more sanding to keep it light, but my wife has been complaining that there isn't enough dust coming out of the model room lately and I need to sand more...
Yeah right...
Of course as you sand these things you see everything, and it all looks like glaring warts all over the airplane until you step back and give it a more realistic assessment. In reality, the surface looks pretty good at this point and it probably won't take much to fill the voids.
Yeah right...
Thanks again guys. Awesome information!
Mike Mulligan
AMA 789641
« Reply #15 on: February 01, 2016, 10:10:14 PM »
If it work for you like it does me,  the first primer coat will show things you wouldn't believe.
