CLICK HERE--><--CLICK HERE
Spray Max 2K Glamour Clear.
Started by Perry Rose, August 29, 2026, 09:00:35 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Perry Rose
I have been testing this two part spray paint. I used it first on my Veco Chief. It didn't take all the paint. Then put it in the fridge right away at 37 degrees F. Three weeks later I needed to repair the nose of my Yak-9 profile so I warmed the can in some hot water and it sprayed normally and cured normally. Today, at 4 weeks, I needed to repair the nose of another plane and I warmed the can in hot water again and it still sprayed and cured normally. There is still some left and I will keep testing it weekly until it cures in the fridge.
Like Like x 1 View List
Dennis Toth
I have used the Spray Max2K and it does stay for a long time.  I had mine in the refrig for several weeks and it still worked. I also used KBS Diamond Clear in spray can, it is moisture activated and as long as you keep it in a cool place will last for months.
Best,   DennisT
Michael LeGate
Sounds like a good reason to buy a little six pack fridge for the shop rather than chance any contamination in the kitchen fridge.
Perry Rose
Here in Louisiana they use contamination for seasoning.
Funny Funny x 1 View List
Tom Luciano
I've used after 6 months in fridge. No ill affects
AMA 13001
