Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 24, 2025, 02:59:37 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Paint and finishing
(Moderator:
RC Storick
Sealing tape edges
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Sealing tape edges (Read 4067 times)
John Castle
Trade Count:
0
Commander
The Bent Pin
Sealing tape edges
on:
February 07, 2009, 11:40:14 AM »
So after you put tape down for outlining a trim design what do you use to seal the edges of the tape to prevent bleed through from the paint. Can I use a little bit of clear dope applied with a Q-Tip?
Logged
John Castle
McMinnville, Oregon
AMA# 589650
Bootlegger
22 supporter
Trade Count:
0
Admiral
Re: Sealing tape edges
Reply #1 on:
February 07, 2009, 02:57:25 PM »
I have used clear dope to seal the edges of tape, but I applied it with a paint brush, "Q" tips might leave some cotton strands in the clear that will cause other problems.
When I use vinyl tape I haven't noticed paint bleed under the edge, but if you feel safer using clear dope then by all means use it.
Hope that this helps, and good luck...........
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Reply #2 on:
February 07, 2009, 09:07:19 PM »
Hmm, well, I usually use vinyl tape for trim and while it doesn't really need a sealer, I usually shoot (with a spray gun) a bit of clear along the tape edge. That's saved me more than once.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Paint and finishing
(Moderator:
RC Storick
Sealing tape edges
Jump to:
=> Paint and finishing
