Building Tips and technical articles. => Paint and finishing => Topic started by: Steve Berry on August 12, 2022, 06:30:52 PM
I finally got around to continuing the finishing process on a Forerunner (foam cores given to me by Tom Farmer himself) that I started building 18-19 years ago. Yes, I know, that's a long time for it to be a hanger queen - life sometimes gets in the way.
I don't remember much of how I actually finished it, other than a few coats of Minwax Polycrylic (water-based), covered everything with silkspan using Polycrylic, sanded, wiped down, and used a Preval sprayer for at least one coat of, I think, auto primer. After that, I set it aside to dry & gas off in preparation to start sanding most of it off. Then life happened. Now, here I am, attacking it with 220, then 320 grit, sandpaper to knock off as much as I can.
This....is going to take a while. The nice thing is that the primer just powders off. Only issue is having to continually wipe off the fine sanding dust from the surface.
Well hopefully it will keep you out of trouble. LL~ LL~
Don't know about that. I do know that I keep bouncing from one project to another, and that's when I actually have time to do any of it, what with being married and having a rambunctious 6yo son, as well as advancing along nicely at work.
I just hope to finish it sometime soon so I have something to fly. Did I mention I'm wanting to convert it from original glow setup (was going to use a .46LA) to electric? It's not so much for the convenience and reliability as much as the quietness - dad is really hard of hearing, and I know unmuffled glow engines played a part in his hearing loss.
Sent from my SM-N986U using Tapatalk
