  • July 19, 2025, 09:45:39 PM
Author Topic: SLC covering - What is a light Filler Coat?  (Read 1049 times)
Offline Vince Mankowski
« on: January 19, 2013, 12:09:41 PM »
I still have a question concerning using SLC covering. So I have started a new  thread.
The Question is: What exactly is a "Light Filler Coat?”
The SLC wing covering process as I see it;
Block sand the foam & give two light filler coats
SLC cover & buff with ScotchBrite to remove 'sheen'
Silkspan 00, two layers down with polycrylic.
sand lightly
Paint with whatever
          OK what exactly is the "Light Filler Coats" directly on  the foam?
          And does the 00 Silkspan have to go down with Polycrilic or can I use Nitrate Dope?
Wood Surfaces (Fuse, tail)
Finish Sand
Polycrilic ?
SLC (buff etc)
00 Silkspan? With polycrlic or Nitrate?
Sand and paint to suit
We are not talking 'front row' finish here, just robust and looking nice.
Anyone have any thoughts?
Vince Mankowski
Re: SLC covering - What is a light Filler Coat?
« Reply #1 on: January 20, 2013, 02:06:16 PM »
I don't think you need a filler coat on foam.   Make sure it is sanded nice and smooth and then vacumn the dust off real good if not better.   Put the SLC covering on.   Doesn't take as much eat as Monokote.
Online bill bischoff
« Reply #2 on: January 24, 2013, 08:14:45 PM »
If you used nitrate, any place the SLC was not completely sealed would experience some disappearance of foam! Using polycrylic first would afford some additional protection. I think "light filler coats" may imply painting the cores with thinned Hobbilite or Model Magic type filler.
My preferred method is "inside out" from what you describe. I cover the foam wings with med. silkspan and thinned Titebond first, making them smoother and stiffer. Then I cover them with SLC and paint them. The paint seals the seams so the covering stays put. You can also use Econokote or other low temp films instead of the SLC and paint, but the seams will start to lift eventually. My experience is mostly with carrier airplanes, which tend to get well lubricated by the exhaust residue. So far, the SLC and paint seems to be holding up very well.
« Reply #3 on: January 25, 2013, 05:28:03 PM »
the filler coat referred to is light weight spachtling compound(Red Devil, DAP, or house brands).  Thin it slightly with 1 tbsp. of water-based varnish to 1 cup of compound.  Brush it on, working it into and small holes in the foam.  If the foam is in spec EIFS foam it won't have many holes.  Sand almost all the filler off, it's mainly to level the surface if there are any dents, wire marks, etc. and get a smooth base for the film.
Applying the covering will raise some grain from the foam, so apply a good coat of primer applied as dry as possible.  Block sand it all off.  Applying silkspan does the same thing, but weighs more and takes more time.  I like rounded tips.  Applying silkspan strips and filler directly to the foam before covering allows you to fill in and smooth the foam when the tips are sanded.
Bill's reverse method works well too.  Takes a bit more time and weight.
Phil C
