  • June 14, 2025, 12:25:52 AM
Author Topic: Silkspan with pinholes??  (Read 10326 times)
Offline Jim Oliver
« on: September 03, 2008, 02:06:03 PM »
Guys,
Recently someone commented about having issues with pinholes appearing after applying dope to silkspan.
I didn't pay much attention until I had the same problem; this with some silkspan with "uncertain pedigree".
In my case, the pinholes didn't appear until I brushed on the color.
Do any of you know the source of the silkspan with the pinholes, and what the "fix" is?
Jim
Jim Oliver
AMA 18475
Offline Jim Oliver
Re: Silkspan with pinholes??
« Reply #1 on: September 03, 2008, 06:53:32 PM »
Ty,
This stuff has had several coats of nitrate clear then, clear + talc, then a couple more coats of clear. And some sanding in between.  I finally got rid of the holes but it wasn't fun.........
It was some old silkspan that I have had for a "while" (I think???).  Anyway, it's gone, now......
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #2 on: September 03, 2008, 09:54:02 PM »
Sounds more like contamination. If you used nitrate and filler and have pinholes, then it sounds like the silkspan is contaminated with something. Oil or similar.
Offline Paul Allen
« Reply #3 on: September 04, 2008, 02:48:09 AM »
Jim
     I had trouble a few weeks back with pin holes in a type of Polyspan tissue.
Let me make it clear it was not Polyspan, but something similar, sold under a
different name.The fix for me was to recover over it with lightweight silkspan
applied wet,worked out good.Will only use Polyspan,if still available,from now on.
