  • June 16, 2025, 04:16:35 PM
Author Topic: Wicks Aircraft  (Read 1040 times)
Online James Mills
Wicks Aircraft
« on: July 20, 2010, 06:45:41 PM »
Do you have to use the Randolph thinner Wicks sells to go along with their paint and clear or can I use DuPont 3608S (like with SIG and Brodak)?
James
AMA 491167
Offline Jim Thomerson
Re: Wicks Aircraft
« Reply #1 on: July 21, 2010, 11:46:35 AM »
I use the Wicks thinners.
Re: Wicks Aircraft
« Reply #2 on: July 22, 2010, 08:10:18 AM »
As stated many times in the past, "Don't mix brands unless you know that it will work".  Some guys have been at it long enough that know what works and what doesn't.  I have several planes that now I wish I had stayed with some manufactor of the material used.  Sometimes it works and sometimes it doesn't. H^^
