  • August 05, 2025, 01:09:46 AM
Author Topic: Sig Magnum  (Read 15861 times)
Offline MarcusCordeiro
Sig Magnum
« on: January 20, 2013, 02:55:05 PM »
Now my idea so far is to have it fisinhed with dope, with some SLC and silkspan on the flaps, stab/elev and spray the basic color.
Then, the decoration I'll go with monokote or vinyl.
Have one color scheme on my mind already.
Today I sanded a lot, it's a bigass plane, almost didn't fit in my compact's trunk... My arms hurt LL~ LL~
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: Sig Magnum
« Reply #1 on: January 20, 2013, 04:37:56 PM »
Marcus,
I see Threads in places about SLC.
I honestly have no idea what SLC stands for or what the material is.
Does seem popular though.
Charles
Re: Sig Magnum
« Reply #2 on: January 20, 2013, 05:00:38 PM »
It's an excellent way to cover your model. Have used a few times. Whatever material I use, SLC will be underneath it.
Have done with silkspan, but I'm curious to use it with silk and polyspan.
I'll do that to add some strength as well.
Marcus
Aces High!
Re: Sig Magnum
« Reply #3 on: January 20, 2013, 07:09:07 PM »
Marcus,
OK, let me get this straight.
SLC is applied with a heat iron, correct?
Then you have used and applied other materials which requiring dope to be applied over this SLC, that was applied with a heat gun, correct?
Charles
Re: Sig Magnum
« Reply #4 on: January 20, 2013, 09:46:39 PM »
Yep, that's how it works. Never saw the point. myself, but other's have used it successfully.
Re: Sig Magnum
« Reply #5 on: January 21, 2013, 02:21:56 AM »
Charles
After I iron the SLC, I brush two coats of dope and put the silkspan on the usual way, and spray two coats of dope and thinner 50/50. It melts the dope previously brushed on and the silkspan sticks to the SLC very nicely, and it takes much less dope to fill in the silkspan. On open Bays it's great because the dope doesn't leak to the inside, like when you are covering wings and the dope drips to the inside, it doesn't happen.
It's really good and adds no weight at all...
Marcus
Aces High!
Re: Sig Magnum
« Reply #6 on: January 21, 2013, 08:00:37 AM »
Charles
It's really good and adds no weight at all...Marcus
Marcus,
Here's my questions.
Does the dope penetrate the SLC? To the wood? Is the material woven? Or does it just float on top? Plastic material?
Yes, I'm going someplace with this.
Charles
Re: Sig Magnum
« Reply #7 on: January 21, 2013, 08:09:40 AM »
It's just like monokote, but lighter.
Check here
http://stunthanger.com/smf/index.php?topic=19859.0
You're gonna love it!!
Marcus
Aces High!
Re: Sig Magnum
« Reply #8 on: January 21, 2013, 08:57:15 AM »
Marcus,
Have you actually used this method before?
Charles
Re: Sig Magnum
« Reply #9 on: January 21, 2013, 09:17:44 AM »
SLC = Super Light Covering.   I was first being used by the combat guys and a gentleman by the name of Phil Cartier started selling it with simple instructions on its use.   The combat guys do not go for 20 point finishes.  They want the plane light and tough.
Go to home dot earthlink dot net slash ~ philcartier   should get you there.    Or google corehouse.
Re: Sig Magnum
« Reply #10 on: January 21, 2013, 09:28:39 AM »
Since I discovered it, I've done 3 planes using it, including the 2 you made those stickers for.
The other one was lost due to engine failure, and though the fuselage was in pieces, the wing covering didn't have a single hole..
Last week I covered a combat model with SLC only, and very good!
Marcus
Aces High!
Re: Sig Magnum
« Reply #11 on: January 21, 2013, 12:21:34 PM »
Marcus,
OK! Just checking!
I'm excited for you!
Looking forward to your finishing this model.
Charles
Re: Sig Magnum
« Reply #12 on: February 27, 2013, 01:38:59 PM »
Better get back at it or will never finish this ship.
I don't use filler, i like to use balsa pieces and CA, sanding it immediately, so the balsa dust mixes with the CA giving it a smooth surface.
Gotta do that in a few places... Adds 0 weight.
Will have more done soon.
Marcus
Aces High!
Re: Sig Magnum
« Reply #13 on: February 27, 2013, 02:03:08 PM »
Well, it's not zero added weight, but it is minimal as long as you don't use TOO much.
Re: Sig Magnum
« Reply #14 on: February 27, 2013, 02:45:46 PM »
Yeah Randy, that's what I meant.
We have to keep 'em light, don't we?? H^^
Marcus
Aces High!
Re: Sig Magnum
« Reply #15 on: February 28, 2013, 05:07:38 PM »
Working on the fairings, will do the flaps first.
It needs some shaping.
Not rushing this...
Marcus
Aces High!
Re: Sig Magnum
« Reply #16 on: March 01, 2013, 11:04:41 AM »
After some sanding...
Marcus
Aces High!
  • Gravitywell
Re: Sig Magnum
« Reply #17 on: March 01, 2013, 12:20:48 PM »
Beautiful work Marcus. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: Sig Magnum
« Reply #18 on: March 01, 2013, 12:34:01 PM »
Marcus,
Looks better after the sanding.  I'll say!
I'll be doing the same thing shortly.
Thanks for the photos!
Outstanding!
Charles
Re: Sig Magnum
« Reply #19 on: March 01, 2013, 06:17:34 PM »
Glenn/Charles
Thanks a lot!
Done a fillet.
I use 30 min epoxi+microballoons. I tape around the wing-fuselage  joint line and apply the epoxi mixture evenly.
Then, I soak my little finger with alcohol and run it over the joint, always from the TE to the LE, pressing the epoxi.
You get a smooth and even finish end wipe off all epoxi excess.
Marcus
Aces High!
Re: Sig Magnum
« Reply #20 on: March 01, 2013, 06:40:45 PM »
Don't you love all the little detail work that goes into finishing a plane?   You're doing great with it.
Re: Sig Magnum
« Reply #21 on: March 01, 2013, 07:28:30 PM »
I'm just following the good advice I've got here, among which there was one that said not to rush the finishing...
Wonder who said that...
Thanks Doc
Marcus
« Last Edit: March 01, 2013, 08:15:48 PM by MarcusCordeiro »
Aces High!
Re: Sig Magnum
« Reply #22 on: March 03, 2013, 12:42:17 PM »
Hi Marcus,
The "woodwork" is looking very good, it should turn out to be a "looker".  I have lost it somewhere, what engine are you planning to use?
Keep it up!
BIG Bear
RNMM/AMM
Re: Sig Magnum
« Reply #23 on: March 03, 2013, 12:50:36 PM »
Glenn/Charles
Thanks a lot!
Done a fillet.
Marcus
Marcus,
I make mine with Polyester resin and micro-balloons. I've only used Epoxy two part glue. I gotta branch out.  n~
I don't use tape as you have. I use my fingers. Different fingers give me a different radius. Wink, wink.   :o
You're progressing!
Hey! How come you never get nasty replies like I do?  H^^  LL~
Charles
Re: Sig Magnum
« Reply #24 on: March 03, 2013, 02:26:49 PM »
I'm going to use one Enya 60 III.
Now I'm going to advance until primer is on.
I thought of a paint scheme,but gave it up, too much work and very little time for complicated stuff.
Robert's model inspired me to look for something simpler, so I still have to come up with something.
But that something will go over the primer, so...
Gonna finish the fillets later on today and move on tothe elevators' fairings and the stab fillets.
One thing at a time. I've ruined great buildings in he past for rushing the finishing.
Won't do that again!
Marcus
Aces High!
  • Gravitywell
Re: Sig Magnum
« Reply #25 on: March 03, 2013, 04:59:52 PM »
Hi Marcus...good looking fillet there.  You mentioned that you always go from the TE to the LE....whats your reasoning?  Just curious. H^^
Glenn Reach
Westlock, Alberta
Re: Sig Magnum
« Reply #26 on: March 03, 2013, 05:49:23 PM »
That's a good question Glenn
I've found it easier to wipe off the excess of epoxi this way, and it also makes the joint line much better looking at the LE, I mean keeping the radius.
It's difficult to get the same shape starting at the LE. At the TE it finishes at "zero", differently from the LE, which has the radius.
I'm gonna use a movie line here:
"Can you dig it?"
Marcus
Aces High!
Re: Sig Magnum
« Reply #27 on: March 04, 2013, 08:30:21 AM »
That comment is from a movie?   I thought it was from the WWE super star who now is a manager.  I also agree that fillets are better done from trailing edge forward.
Re: Sig Magnum
« Reply #28 on: March 04, 2013, 09:14:18 AM »
Here
Love this movie!!!!
Marcus
Aces High!
  • Gravitywell
Re: Sig Magnum
« Reply #29 on: March 04, 2013, 10:43:57 AM »
Thank you Marcus (and John).  As soon as I read your answer I saw it in my head and understood perfectly! H^^
Glenn Reach
Westlock, Alberta
Re: Sig Magnum
« Reply #30 on: March 04, 2013, 11:24:45 AM »
Marcus,
If you close your eyes and just listen, sounds farmiliar.
Can't quite place it though?
Hey Marcus!
IS IT PAINT TIME!!
Got a scheme?
Charles
Re: Sig Magnum
« Reply #31 on: March 04, 2013, 04:36:06 PM »
I've always wanted to finish a model with the Thunderbirds color scheme, thought of doing that, but right now it's not the best choice.
I've decided on white as base and red and blue marks to match the colors on the sticker.
Just don't know how the lay out will look like...
I've still got some time to think :!
Marcus
Aces High!
Re: Sig Magnum
« Reply #32 on: March 04, 2013, 06:12:05 PM »
Marcus,
What sticker? Did I miss something?
Charles
Re: Sig Magnum
« Reply #33 on: March 04, 2013, 06:34:14 PM »
Marcus,
Charles
The sticker taht comes with the kit, MAGNUM in blue, white and red.
Marcus
Aces High!
Re: Sig Magnum
« Reply #34 on: March 04, 2013, 07:38:27 PM »
I guess by tomorrow I'll be done working on the wings.
Those fillets are almost done... S?P
Marcus
Aces High!
Offline MikeyPratt
Re: Sig Magnum
« Reply #35 on: March 24, 2013, 04:55:52 PM »
Marcus
Looking GOOD Marcus.  Keep it going and you should have a great flyer   #^.
Later,
Mike Pratt
Re: Sig Magnum
« Reply #36 on: March 24, 2013, 05:46:17 PM »
Later,
Mike Pratt
Thanks Mike!!!!
I guess it doesn't get better than that... a compliment from the designer of the model!! I'm really honored #^ :)! 8)
It's been so busy the past few weeks, but I should be back at it this week.
Marcus
Aces High!
Re: Sig Magnum
« Reply #37 on: March 25, 2013, 05:18:18 AM »
Those fillets are almost done... S?PMarcus
Marcus,
Please, tell how you did your wing fillets. What did you use? They look great.
Charles
Re: Sig Magnum
« Reply #38 on: March 25, 2013, 10:18:00 AM »
Glenn/Charles
Thanks a lot!
Done a fillet.
Marcus
That's it!!
Marcus
Aces High!
Re: Sig Magnum
« Reply #39 on: March 25, 2013, 12:14:11 PM »
Marcus,
Got it!
In fact, now I remember you mentioned that once before. Meds, they make you forget.  n~
Do you wait till it's cured before you pull the tape?
Charles
Re: Sig Magnum
« Reply #40 on: March 25, 2013, 03:41:07 PM »
No, as soon as I'm done I pull it off, otherwise it'll stick to the wood 'cause of the glue.
Marcus
Aces High!
Re: Sig Magnum
« Reply #41 on: March 29, 2013, 06:42:48 PM »
Here a elev fairing...
Still needs some work.
Marcus
Aces High!
Re: Sig Magnum
« Reply #42 on: March 29, 2013, 09:51:41 PM »
 Marcus, can we see a couple overall pics of the model at this stage? I recently picked up a Magnum kit and am looking for some inspiration and ideas.
Re: Sig Magnum
« Reply #43 on: March 30, 2013, 05:44:43 AM »
Wayne
That's great you got a Magnum too!!
I'll work on the othr side fairing today and will post a few pics of the model as it is now... Finishing is a phase that seems like you're not progressing, but there're so many details and little things that pics don't show...
Marcus
Aces High!
Re: Sig Magnum
« Reply #44 on: March 30, 2013, 07:18:23 AM »
Marcus,
Som guys just use glue on their hinges, different types.
I use glue but always pin them also.
Will you pin your hinges?
Charles
Re: Sig Magnum
« Reply #45 on: March 30, 2013, 09:38:01 AM »
You bet Charles...
That's the only way I do it.
Marcus
Aces High!
Re: Sig Magnum
« Reply #46 on: March 30, 2013, 01:52:02 PM »
Marcus,
You're progressing!
Charles
Re: Sig Magnum
« Reply #47 on: April 03, 2013, 07:31:38 PM »
The stab fillets... i'm way behind schedule with this ship... :P
Marcus
Aces High!
Re: Sig Magnum
« Reply #48 on: April 03, 2013, 08:22:44 PM »
Marcus
Marcus,
Why do you think you're, "way behind schedule." ?
What, you're bouncing between, how many, six or seven models.   LL~ LL~
Looks to me like you're moving right along, at least on this one.
Tail feathers are shaping up. Looks great, good job!
Charles
Re: Sig Magnum
« Reply #49 on: April 04, 2013, 05:45:51 AM »
Thank you Charles
What I meant is that sometimes one can't do as much as it was planned.
I'm building 2 ships only... LL~
Work has been killing me, but it's never say die, right?
Today I'm going to have some free time and try to advance a little more both ships.
Marcus
Aces High!
