  • July 31, 2025, 05:34:46 AM
Author Topic: New (to me) Product - AquaCoat  (Read 5760 times)
Offline Steve Berry
« on: October 08, 2024, 07:23:54 PM »
Does anyone know anything about this stuff, AquaCoat?
They have a clear grain filler - https://aquacoat.com/products/clear-grain-filler
They have a clear water-based lacquer - https://aquacoat.com/products/aqua-coat-clear-topcoat
They even have a sanding sealer - https://aquacoat.com/products/aqua-coat-x-119-sanding-sealer
If their YouTube videos are to be believed, it can easily withstand straight grain alcohol with no issues https://youtu.be/Giuo25BmrDE?si=-wI6gI_TdkuIOiT3
Money is a bit tight for me right now, otherwise I'd get some and test it. Does anyone here have any experience or thoughts on it, positive or negative?
Offline kevin king
Re: New (to me) Product - AquaCoat
« Reply #1 on: October 12, 2024, 01:08:34 AM »
No experience with that particular product, but any time I've veered off the status quo it winds up being more expensive, more heavier, with less than impressive results.
« Reply #2 on: October 12, 2024, 01:52:38 PM »
   I am not sure what "status quo" means in this case. Since people have mostly moved on from dope, there are a pretty wide array of different materials used, almost all automotive products, most of which are more durable and lighter. More expensive, yes.
     I think "aqua coat" is a water-based wood floor finish. I don't know if it is fuel proof, but that probably doesn't matter as much as it used to. Anything used for a floor is going to be pretty tough.
« Last Edit: October 12, 2024, 05:45:55 PM by Brett Buck »
