  • August 02, 2025, 07:26:48 AM
Author Topic: Moisture Weight .  (Read 1137 times)
Moisture Weight .
« on: October 28, 2020, 08:52:04 PM »
O.K. dead serious .
If the white ' blushing ' ( as the poms say ) is MOISTURE trapped it the dope / lacquer , wotsit WEIGH .
as in if you painted everything during the flood , so all the lacquers blushed , is it gunna weigh measureably more ..?
knees trembling icon . ;D
Re: Moisture Weight .
« Reply #1 on: November 01, 2020, 11:14:07 AM »
AM,
I don't think it adds any real weight, just causes the blush. Usually if you give another coat with a bit of retarder it will clear up with no problems. I usually do a test piece to check if the mix is ok.
Best,   DennisT
