  • July 16, 2025, 07:22:51 PM
Author Topic: Shrinking polyspan  (Read 3649 times)
Jim Roselle
Shrinking polyspan
« on: May 06, 2017, 04:09:12 PM »
My last few builds I have started using polyspan and dope instead of monokote. I use a hardware store heat gun to shrink it and invariably get pinholes if not complete blow throughs because the gun is way to hot. Can I shrink polyspan effectively with a monokote iron or do I need to purchase a monokote gun? What are other people using?
 Jim
Rick_Huff
Re: Shrinking polyspan
« Reply #1 on: May 06, 2017, 04:11:47 PM »
Jim,
In my experience, an iron works perfectly.
Rick
« Reply #2 on: May 06, 2017, 04:51:36 PM »
     You can blow holes in any covering with a hobby heat gun also if you don't get the hang of using them. I use an iron for most work like that also. All the irons aren't the same, though. After trying several that I find cheap at swap meets and such, I think I like the Coverite/Century21 version the best.
« Reply #3 on: May 07, 2017, 08:23:11 AM »
I've noticed the grain opening up a bit when I shrink Polyspan, too.
I don't blame the heat gun.  With good finesse you can get the temp right with a combination of distance & time.
I'm thinking of doing a better job sanding out every imperfection of the structure so I don't damage the covering during installation.
Offline jfv
« Reply #4 on: May 08, 2017, 12:45:31 PM »
I use an iron all the time with polyspan.  Works great especially around the wing tips.
Jim Vigani
« Reply #5 on: May 09, 2017, 10:21:00 AM »
Don't shrink Poly-Span using hot air gun.  Even if you do make a hole in it a scrap piece doped over the hole will disappeared with more coats of dope.
Online Tim Wescott
« Reply #6 on: May 09, 2017, 12:31:42 PM »
Keep the gun moving.
This is the rule for 'coat, too -- watch the film, move the gun away when it starts to shrink, and have an idea of how long you can dwell on any one spot before Bad Things happen.  A 'coat gun may be nicer, but a shop gun should work.
Offline Mike Haverly
« Reply #7 on: May 09, 2017, 07:21:23 PM »
Guess I'm doing things wrong again.  I rarely use an iron but use my hot air gun all the time.  My stuff usually turns our OK though.  Whatever works for the user is the one to use.
Offline Sean McEntee
« Reply #8 on: May 30, 2017, 02:05:36 PM »
     I use a monokote heat gun and echo what was previously mentioned:  keep the gun moving.  Not meaning to "finger wave" but work slowly and don't get things too hot.
Online Tim Wescott
« Reply #9 on: May 30, 2017, 06:58:12 PM »
Yes, like, the judges have to get their eyeballs to within 9 inches of your finish to find flaws.
« Reply #10 on: May 30, 2017, 08:20:45 PM »
A tip I learned from watching Sparky cover a wing with Polyspan is to repair blowouts with silkspan instead of poly. It hides the repair better.
Rusty
« Reply #11 on: May 31, 2017, 10:24:49 AM »
I dare you to find my repairs after too much heat left a hole.  I tear the poly-span just like you would do with silk span.
« Reply #12 on: May 31, 2017, 07:01:56 PM »
Okay, Doc, you're on. It's Heat Guns, Dope and brushes at High Noon! LL~
