Building Tips and technical articles. => Paint and finishing => Topic started by: frank mccune on February 27, 2024, 02:44:31 PM
Hello:
Would it be a wise choice to take four gallons of dope and store it in smaller containers to promote storage life. Right now, it is being stored in a five gallon metal tin. Perhaps, four one gallon tins would be better.
Thoughts,
Tia,
Frank
Yes, get rid of the air-gapped big can, but break down to whole gallons plus smaller pieces . Consume each gallon upon demand...in other words, open/decant and use one gallon at a time. First one breaks down to 3 quarts and then smalls (4 or 8 oz...12-16 oz if you build big and use a lot). Do the next one once you've used and broken down the first bunch.
Hi Jim:
Thanks for the prompt reply.
I will do that asap. Yes, I really like to do silk and dope finishes.
Frank
I would do so with caution. I bought a gallon of Randolph clear butyrate a few years back with a friend. We split it 50:50. He found some paint cans at a store and decanted some into those. Whatever was on the inside of those cans discolored the dope. The original Randolph can is still clear. Maybe a really good paint shop could advise on suitable cans for lacquer. I wouldn't trust a big box store's cans...but you can always give it a try.
Aha !! you have four gallons in a five-gallon can. I would either decant it into smaller cans and store them upside down, or flood the can you have with Argon and make sure it is sealed very well. And my Argon idea is probably stupid and easier said than done, since I've never had Argon and never attempted to replace atmospheric air with Argon and store it. I can think of ways to attempt it, but I'd probably be wrong.
