  • July 15, 2025, 04:57:56 PM
Author Topic: RUSTOLEUM PROBLEMS  (Read 1592 times)
Mike Griffin
RUSTOLEUM PROBLEMS
« on: November 29, 2011, 12:31:25 PM »
I have used Rustoleum primer and Rustoleum paints over a nitrate base for years and never had a problem with it.  HOWEVER, the last plane I painted with Rustoleum was a disaster.  I laid down my nitrate dope base as always and let it gas off for about a month.  Then I shot it with the Rustoleum primer right out of the can.  I waited another week and sanded the primer and then shot it with Rustoleum color.  It took the Rustoleum a lot longer to dry that usual.  I let the plane sit for a few days and went back to mask it off for trimming.  This is when I discovered that the primer and paint had not adhered to the polyspan and dope.  I noticed a little chip that had flaked off and I took my finger and rubbed the finish and the paint was like a film and had not stuck to the plane.  You could put a piece of masking tape on the wing and carefully peel it back and the paint just came right off with the tape.
I picked up the phone and called Tom Morris because I knew he had also finished planes like this for years.  He had the same thing happen to him just recently and he has quit using it.  It may be that Rustoleum has changed their formula.  If it were just me, I would say I did something wrong but when Tom told me he had the same thing happen to him, I think something has changed and I do not think it is the dope.
Just wanted to give you guys a heads up who have been using Rustoleum to paint with.
Re: RUSTOLEUM PROBLEMS
« Reply #1 on: November 29, 2011, 12:38:26 PM »
Thanks Mike.
I suspect that this is just going to show up as a compatibility problem with nitrate, which I don't use under Rustoleum -- but before I go commit a paint job to a new can of Rustoleum, I'm spraying me a test patch!!
Offline Douglas Ames
« Reply #2 on: November 29, 2011, 03:15:16 PM »
Which Rustoleum are you using? Gloss Protective Enamel? There's a chance it's the primer, there are several types of that too.
AMA 656546
Mike Griffin
« Reply #3 on: November 29, 2011, 05:45:28 PM »
Hi Tim and Doug.
I have been using Rustoleum Gloss enamel for years over nitrate and never had a compatibility problem.  The primer did  not even stick to the polyspan.  It was like there was some sort of teflon on the dope.  I really do not understand it.. never ever had this happen before.  I am going to take acetone and see if I can strip everything off and try something different...
« Reply #4 on: November 30, 2011, 08:55:30 AM »
Hi Mike,
Try a traditional dope finish over the Nitrate (in a small area on the bottom).  If the butyrate dope peels off, it's the nitrate.  Clean everything with Kryl Kleen or similar.
Big Bear
(P.S. I'm betting the butyrate will not peel from the nitrate)
Mike Griffin
« Reply #5 on: November 30, 2011, 12:40:43 PM »
OK Bill.  I will give it a try Thanks
« Reply #6 on: December 13, 2011, 04:01:54 PM »
HI Mike,
Did you find a solution to the problem? ???
Big Bear
