Building Tips and technical articles. => Paint and finishing => Topic started by: Dwayne on April 22, 2019, 04:59:40 PM
...Is not fuel proof. That is all. HB~> :'(
WHERE HAVE YOU BEEN!!!!.. Sometimes the best lessons are the hardest learned, but it's great for sand paper sales! y1 y1 This post needs to be pinned to the top of the forum!!!
Luckily the effected areas cleaned up pretty quick with a lot of rubbing with alcohol, will pick up some Spray Max 2K and life goes on. ::) n~
Any reason not to use it on an electric?
I guess I should coat the parts I sprayed a couple days ago with 2X with something fuelproof then? ;D Ran out of Minwax, so thought I would give the 2X a try. Well, it looks like I am off to epoxy the firewall now.
No, you can use anything you want on a electric. y1
y1 y1
