  • July 13, 2025, 03:53:10 PM
Author Topic: Rubbing Alcohol, Denatured Alcohol?  (Read 3200 times)
Offline David Barber
« on: October 19, 2011, 03:37:17 AM »
Hello,
I am starting to put together my ARF PT-19 from hangar,
it lists using rubbing alcohol to remove felt pen marks also excess epoxy, I am having trouble buying this product.
Any thing else I can use?
David,
AUSTRALIA.
Offline BillLee
Re: Rubbing Alcohol, Denatured Alcohol?
« Reply #1 on: October 19, 2011, 04:47:12 AM »
Any kind of alcohol available (hardware store, drugstore, etc.) will work just fine for removing magic marker.
Bill Lee
AMA 20018
« Reply #2 on: October 19, 2011, 09:59:49 AM »
Perhaps it's a language difference?  In the US "rubbing alcohol" refers to isopropyl alcohol, and it is readily available.
So if you can get isopropyl alcohol by any other name, or (like Bill said) just about any other alcohol, you should be all set.
Try single-malt scotch.  It's more expensive, but it'll make your plane smell fine.
« Reply #3 on: October 19, 2011, 01:57:25 PM »
I think it is the language difference, I went to our hardware store, your drug store,
I was told No, go to the chemist, fine, but then im told $30 for 500ml also they wanted to no what I was using it for.
Any Australian readers got some ideas?
Thanks guys.
Online Dick Pacini
« Reply #4 on: October 19, 2011, 02:07:40 PM »
I found this with Google.  It is supposed to be readily available down under.
http://isocol.com.au/
AMA 62221
Offline BillLee
« Reply #5 on: October 19, 2011, 02:12:56 PM »
Thanks guys.
I can go to any Home Depot or Lowes or ... in the United States and find alcohol by the gallon in the paint department. Is Australia THAT different?
Bill Lee
AMA 20018
« Reply #6 on: October 20, 2011, 02:08:54 AM »
Thank you guys for all the info,
Problem solved.
« Reply #7 on: October 20, 2011, 08:35:44 AM »
$30 for 500ml?!?  That's definitely priced for drinking, although it's no single-malt.
Just out of curiosity, what's the Oz-specific solution to this problem?
Offline PerttiMe
« Reply #8 on: October 20, 2011, 09:09:41 AM »
Car window cleaning fluids might work very well. The arctic grade ones are mainly ethanol.
Offline Peter Nevai
    • C3EL
« Reply #9 on: October 20, 2011, 11:35:58 AM »
As it is a ARF and the marks are probably on the film covering, then just about any solvent would work. Benzine, Denatured Alcohol, Laquer Thinner just to name a few. Turpentine would probably not work. MEK ans acetone work just fine as well. In a pinch you can even use nail polish remover.
Offline Geoff Goodworth
« Reply #10 on: October 20, 2011, 09:07:01 PM »
Isocol is available in Oz. Not 100% iso-propyl-alcohol but it's available in supermarkets.
A problem we have is getting what we call commercial purity iso-propyl-alcohol. The stuff from the chemist/pharmacy/drug store is medicinal/reagent purity, hence the price.
Offline Larry Renger
« Reply #11 on: November 01, 2011, 10:38:29 PM »
Grocery store version will work just fine.  If I recall, it is 90% pure, the rest water.
« Reply #12 on: November 01, 2011, 10:45:02 PM »
Grocery store isopropyl is all over the map.  Various stores around here sell 70%, 90%, and 99%.  I get the 99% for thinning epoxy and whatnot, and keep 70% around for shrinking tissue on rubber-powered planes and for cleaning up felt-tip pen lines.
« Reply #13 on: November 06, 2011, 07:50:57 PM »
    Hmm , I can get anhydrous IPA from the local electronics store for $4/quart or so. It's used for cleaning circuit boards.
Offline ash
« Reply #14 on: November 07, 2011, 05:14:02 AM »
Methylated Spirits is probably the easiest thing to get in Australia (ethanol+methanol+water+denaturant) that will clean off the ink. IPA is hard to get in NZ too, because it's used for processing illicit narcotics, so the authorities like to assume that anyone with a need for it must be a criminal.
« Reply #15 on: November 07, 2011, 12:43:55 PM »
Wow. We buy Isopropyl Alcohol here at the local store for like $1 for a pint. Watch out with denatured alcohol. It will remove paint if you rub too hard.
Offline Jim Thomerson
« Reply #16 on: November 07, 2011, 02:55:14 PM »
Aftershave lotion should work.
Offline Dan Bregar
  • Field Marshall
« Reply #17 on: November 07, 2011, 06:04:00 PM »
Isopropyl will remove Brodak & Randolph dope also.   :)
AMA 33676
