  • June 17, 2025, 01:33:09 AM
Author Topic: ..dopes...  (Read 2479 times)
Offline Bootlegger
..dopes...
« on: October 23, 2011, 05:08:49 AM »
   Fellow's I am thinking about trying some Certified dopes from Aircraft Spruce.
 Does any one have experience with this dope, and how do you like it?
  Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
larry borden
Re: ..dopes...
« Reply #1 on: October 23, 2011, 08:45:02 AM »
All I use now is Randolph dope from an aircraft supply co. in Fort Worth. I do use Brodak's crystal clear for the final clear coats. I also use Dupont 3608S for thinner and it works for nitrate and butyrate.
Offline Jim Thomerson
Re: ..dopes...
« Reply #2 on: October 25, 2011, 11:23:29 AM »
Certified works fine for me.
Re: ..dopes...
« Reply #3 on: October 25, 2011, 11:37:50 AM »
I checked recently, and Wicks has Randolph dope for significantly less (50-60% the price) as Aircraft Spruce.  You might see if they have Certified as well (or if their prices have gone up).
Offline billbyles
Re: ..dopes...
« Reply #4 on: October 26, 2011, 10:58:29 AM »
   Fellows I am thinking about trying some Certified dopes from Aircraft Spruce.
  Thanks a lot...
Certified is a good product but they have a limited choice of colors.  Also, their prices used to be lower than Randolph's but are now quite a bit higher.
I now use Randolph clear for buildup from bare balsa through ready for color, and usually Randolph colored butyrate because they offer a wide selection of colors.  For the final clear topcoats over the colors I use Sig Light-Coat butyrate because it is more fuel-resistant than any other brand I have used.
Bill Byles
AMA 20913
So. Cal.
Offline Peter Nevai
    • C3EL
Re: ..dopes...
« Reply #5 on: October 27, 2011, 12:55:20 PM »
Welcome to the ancient order of Certified Dopes (AOOCD) Your membership materials will be sent to you by mail along with your contribution envelope.
Thank You for your support.
Head Certified Dope.
Offline Bootlegger
Re: ..dopes...
« Reply #6 on: October 27, 2011, 01:36:15 PM »
   y1   Bill Byles, I sent ya' a P/M...Gil #^
Gil Causey
AMA# 6964
Re: ..dopes...
« Reply #7 on: October 28, 2011, 06:49:57 AM »
Anyone ever use or try automotive paint and finishing products?
CB
Offline billbyles
Re: ..dopes...
« Reply #8 on: October 28, 2011, 09:48:36 AM »
Got it, Gil; sent you a P/M & an email.
Bill Byles
AMA 20913
So. Cal.
Re: ..dopes...
« Reply #9 on: October 30, 2011, 04:11:12 AM »
CB
Hi CB,
I have used acrylic lacquer a LOT ( ton of builders used that when t was more readily available), along with the newer basecoat/clearcoat systems.  Now, I use a lot of Duplicolor acrylic lacquers in the touch up spray can for colors.  It has never caused "me" a compatibility problem with dope.
The automotive urethane 2 part clear is a favorite clear top coat for many, many builders.  Just go light with it as it can get HEAVY real quick,  It is, however pretty fuel proof when cured and VERY shiny.
Big Bear
Offline Bootlegger
Re: ..dopes...
« Reply #10 on: October 31, 2011, 05:28:58 AM »
  Thanks a lot fellow's, I 'ppreciate all the info... ~>
Gil Causey
AMA# 6964
Offline adam collver
Re: ..dopes...
« Reply #11 on: November 05, 2011, 03:02:18 PM »
does laquer thinner work better to clean brushes than just regular paint thinner becuase after my brushes dry they are harder than they should be and coloured a whitish colour after they dry srry for being off topic.
Re: ..dopes...
« Reply #12 on: November 05, 2011, 03:23:41 PM »
Yes. Cheap lacquer thinner will work for cleaning brushes.
Re: ..dopes...
« Reply #13 on: November 05, 2011, 04:46:48 PM »
thanks
larry borden
Re: ..dopes...
« Reply #14 on: November 05, 2011, 05:24:35 PM »
I use acetone for cleaning brushes and spray guns.  It's cheaper than dope thinner and works great.
Re: ..dopes...
« Reply #15 on: November 06, 2011, 07:22:47 AM »
I sprayed some Aerogloss clear and tried to clean the gun with cheap lacquer thinner.  I got grey jello as a result and had to switch to Aerogloss thinner (all I had at hand) to clean it up. HB~>
Offline billbyles
Re: ..dopes...
« Reply #16 on: November 06, 2011, 01:57:48 PM »
I'm not familiar with the current formulation of Aerogloss, however the problem you described above sounds much like you may have gotten hold of some of the new low VOC lacquer thinner.  DuPont labels it V3608S whereas the previous version that would work with dope was 3608S; I don't know what PPG or other brands label theirs.  Using the V3608S will cause dope to jell & turn a grayish color, & you are correct...it won't even work to clean brushes.
Bill Byles
AMA 20913
So. Cal.
