  • July 13, 2025, 01:45:29 AM
Author Topic: Rit Dye on Balsa  (Read 1693 times)
Rit Dye on Balsa
« on: April 26, 2020, 03:25:30 PM »
blank
« Last Edit: August 23, 2021, 09:08:17 PM by Motorman »
Re: Rit Dye on Balsa
« Reply #1 on: April 26, 2020, 06:27:12 PM »
  Been done already in R/C soaring and free flight. Investigate spray can stencil ink. Spray your balsa parts lightly after cutting them out and before assembly. Glue will still penetrate the balsa, but use glue sparingly. Like you found out, everything has to be prefitted and sanded, or you sand the colors off. Not widely seen because of the extra work involved for what most perceive as an underwhelming effect.
« Reply #2 on: April 27, 2020, 09:08:58 AM »
I always preferred to dye the silkspan with Rit dye.
« Reply #3 on: April 28, 2020, 01:26:11 PM »
Does it run when you dope it?
No. At least I've never had it run.
« Reply #4 on: April 28, 2020, 02:37:27 PM »
MM:
A gentleman named Bob Branch built a profile with a CF tube fuselage that he painted before covering with transparent U-cote.  Here's the link, starting at post #22
https://stunthanger.com/smf/gettin-all-amp'ed-up!/c-14-carbon-fuse-electric-profile/msg218540/#msg218540
Online Brent Williams
« Reply #5 on: April 29, 2020, 02:06:34 PM »
On the low buck DIY side of things, I have used DesignMaster floral dye to tint both balsa and the adhesive side of clear lamination film.
DesignMaster stuff is available at craft stores.  Michael's, ect.  Unfortunately, there are only a few colors that I would consider using.  https://dmcolor.com/explore/color-sprays/tintit-sprays/#&panel1-1
I would think you could also try using Higgins or a similar non-fading ink dissolved in clear dope, or possibly a bit of denatured alcohol.    https://www.higginsinks.com/dyeinks
TransTint is an amazing product, used extensively in the expensive guitar realm.
« Last Edit: April 29, 2020, 03:10:12 PM by Brent Williams »
« Reply #6 on: April 29, 2020, 02:38:02 PM »
Pete Peterson gave the definitive tutorial on how to tint clear dope using House of Kolor Intensifier Kandy Koncentrate (KK series).
Very vivid transparent color when done this way.
Jan/Feb 2009 Stunt News.  https://pampacl.org/stuntnewsdownload.php?file=/wp-content/uploads/2017/08/SN_Magazine_Jan_Feb_2009.pdf
 http://flyinglines.org/ff.10.petejamison.jpg. Pete's Jamison
http://flyinglines.org/reg.16.classicjudges.jpg Mike Haverly's Chizler
« Last Edit: April 29, 2020, 04:58:01 PM by Brent Williams »
« Reply #7 on: April 29, 2020, 03:33:43 PM »
The Orange Chizler is Mike Haverly's plane. A flying buddy of Pete's. And mine.
