  • July 18, 2025, 07:18:47 PM
Author Topic: Reporting on Varathane  (Read 1582 times)
Offline David Ruff
« on: March 15, 2018, 12:47:53 PM »
FYI
I sprayed Varathane from a rattle can over Brodak water slide decals/Brodak Crystal Clear butyrate.  It worked fine.
I will let you know how well it works after it gets hit with fuel and oil.
Retired Army
Offline Mike Haverly
Re: Reporting on Varathane
« Reply #1 on: March 15, 2018, 08:13:32 PM »
Just wondering, why didn't you just spray Brodak crystal clear since that's what you were already using?
  • Gravitywell
« Reply #2 on: March 16, 2018, 12:09:37 AM »
I use Varathane because I can't afford dope, nor can my wife breath the vapours for medical reasons.  I use it straight out of the can (or spray can, but that's expensive) and have never had a failure.  I have found it to be absolutely fuel proof. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline David Ruff
« Reply #3 on: March 16, 2018, 05:09:35 AM »
I don't have a spray gun.  So I don't spray except if I use a rattle can.  Also, dope WILL eat the decals.
Point being Varathane does NOT seem to eat the decals or cause a problem when sprayed over dope.
Retired Army
« Reply #4 on: March 16, 2018, 08:13:30 AM »
Dope won't "eat" the decals, I've done it many times.  Light coats at first then more aggressive.  I guess the point is moot if you don't have spray equipment.
Varathane is a good product also, I've used it for other projects.
Offline kenneth cook
« Reply #5 on: March 17, 2018, 06:53:57 AM »
           It does turn yellow pretty badly when exposed to the sun.
