  • August 02, 2025, 07:08:50 AM
Author Topic: Carbon Tissue over Edges  (Read 1762 times)
Online Motorman
« on: October 06, 2020, 09:26:53 PM »
blank
« Last Edit: August 20, 2021, 06:56:43 PM by Motorman »
Offline Jim Hoffman
Re: Carbon Tissue over Edges
« Reply #1 on: October 07, 2020, 08:38:49 AM »
My technique
•   Seal balsa w/ Z-poxy, block sand with 240
•   Apply 2 coats Nitrate
•   Light block sand with 320 paper
•   apply CF matt. I use either pure thinner or 90% thinner  (I use nitrate thinner, but I am told that butyrate is fine also)
•   Overlap on bottom of surface, not the TE.
•   Use torn edges at the overlap
•   Add CF matt one side at a time.
•   After it dries, kiss the edge lightly with say 400 paper, maybe two passes.  Just making it fair smoother to the balsa.
•   Add 2nd piece to bottom of surface.  Torn edge also.  ½ “ overlap is plenty.
•   After it dries, kiss the edge lightly with say 400 paper, same as above.
•   5 coats butyrate,  begin adding a little zinc Stearate in the 3rd or 4th coat. Do not sand until maybe the 4th coat.  Any sanding is very light  (400 grit paper)
•   You can add more clear dope and Zn Stearate depending on the results you are seeking.
« Last Edit: October 09, 2020, 03:23:39 PM by Jim Hoffman »
Offline Jim Hoffman
« Reply #2 on: October 07, 2020, 11:57:22 AM »
More weight and work than necessary
Offline Jim Hoffman
« Reply #3 on: October 09, 2020, 11:54:52 AM »
Do not thin the Zpoxy, it’s already quite thin.  Properly applied there will be essentially no zpoxy on the surface.  I don’t think it would adhere the CF
Do your own experiments if you wish.
« Reply #4 on: October 09, 2020, 02:46:02 PM »
   And, it won't soften the sizing on the carbon, or cause it to lie flat. Dope is really the ideal material for putting down this sort of material. If you use epoxy, you need something to press it down flat to the surface while it cures - vacuum, foam rubber, something like that.
