  • July 31, 2025, 06:47:11 PM
Author Topic: removing paint from canopy  (Read 4330 times)
Offline John KruziK
« on: January 31, 2009, 01:17:30 PM »
Is there any way to remove dried rustoleum from a canopy? I think this plane is cursed, its fighting me every step of the way. Anyway tape lifted on inside of canopy of a Pt-19. Now I have a nice stripe on both canopies. Thanks John
AMA 874027
Offline Balsa Butcher
  • High Desert Flier
Re: removing paint from canopy
« Reply #1 on: January 31, 2009, 04:50:48 PM »
Don't know if this is possible due to access issues but if you could use 000 steel wool to "sand" (wool?) the paint off.  This will leave fine scratches in the plastic.  Then air brush a light coat of Sig Lite-Coat over the area you just wooled and the scratches will disappear.  Should not have a compatibility problem if the first coat is misted.  Try on a piece of scrap canopy first so you know what to expect.  If the Rusteolum has not reacted with and softened up the canopy plastic it should work.
Pete Cunha
Sacramento CA.
AMA 57499
Offline John KruziK
« Reply #2 on: February 01, 2009, 08:49:32 AM »
I'll give it a try. Thanks John
AMA 874027
