  • July 20, 2025, 03:46:14 PM
Author Topic: Removing Old Silk  (Read 1458 times)
Removing Old Silk
« on: May 06, 2020, 07:23:50 PM »
blank
« Last Edit: August 23, 2021, 01:00:53 PM by Motorman »
Re: Removing Old Silk
« Reply #1 on: May 06, 2020, 07:37:12 PM »
I've got an old combat job with good bones that I'm trying to get in the air again. The Sig silk was put on with butyrate dope in 1978. Don't know what's wrong but if you touch it it rips very easily so I want to remove it. I tried a couple of things like pulling it off, scraping, sanding and heat. Will try dope thinner ect. tomorrow but just want to ask for any advise you might have.
Motorman 8)
What condition is the silk on sheeted areas, including LE, TE and rib tops?
Without seeing the model, I would simply remove all the open bay areas with a #11 blade and be done with it.
I removed the silkspan on the ARGO 2 wing this way and recovered the wing with silk. Dry actually using CA in minutes, not hours. There's photos of this and text in the Build Thread.
The fuselage and other areas were fine.
A suggestion.
Charles
Offline Dane Martin
  • heli pilot BHOR
« Reply #2 on: May 07, 2020, 07:05:03 AM »
From Bob DeShields...  (this was in response to a few guys going on about how amazing his models are. The picture is a restored 20 year old model)
Ok Guys no tricks or Magic, I use the large thick black garden trash bags and dump 2/3 Cups of Lowe's or Walmart laquer thinner in the bag for 1/2As you usually can put the wing and stab in the bag but if not do 1 at a time . Your model needs to built with CA or you will have a kit when you open the bag 😂 I seal the end of the bag with a rubber band it does help to turn the bag to get thinner on the parts but mostly the fumes do the job . Never tried a model built with Titebond ? So not sure if the thinner would affect it I don't think so .after 2 hrs or so pull one part out and CK it do 1 part at a time if it drys you may have to put it back in the bag for a little while. It's one of those being patient things but is does work . With large wings I do 1/2 at a time buy taping the bag tight around the middle .you may have to pick or sand a stubborn areas but let dry sand with 400 add coats of dope and recover.
« Reply #3 on: May 07, 2020, 12:00:02 PM »
I've used stripper. Just paint it on, wait a bit and peel off covering. Around here the brand is Jasco, but I'm sure there are others in other parts of the country.
Offline Dane Martin
  • heli pilot BHOR
« Reply #4 on: May 07, 2020, 08:02:32 PM »
We have a stripper around here called Jasmine too but I don't have time for that.
Ha!
I'm not sure the effects of stripper on epoxy... I would wonder about that
Offline Tom Luciano
« Reply #5 on: May 08, 2020, 02:55:54 PM »
I actually stripped a VooDoo that was silked from the seventies. I cut out open bays as Charles suggested then I kept brushing on acetone to saturate the doped down areas and peeled back as I was doing. Slow painfull processed but worked. Don't be tempted to just pull off ribs as some rib will come with it. Ask me how I know. Plane was originally built with Ambroid. I did spot all joints with CA before Monokote.
Tom
AMA 13001
