  • July 17, 2025, 05:44:58 AM
Author Topic: Removing Monocoat glue from dope  (Read 3145 times)
« on: June 27, 2017, 10:17:35 PM »
Old plane, old dope, some old Monocoat over some of the dope.
Is there a way to get Monocoat off of dope after 30 years, short of lots of careful sanding?  I'm assuming that anything that'll eat Monocoat glue will eat dope, but if there's a magic solvent that works the other way, I'm listening.
Offline billbyles
Re: Removing Monocoat glue from dope
« Reply #1 on: July 02, 2017, 11:00:11 AM »
Hi Tim,
You can use a paint cleaning solvent which will remove the adhesive without harming the dope.  The solvents that I use are Sikkens M-600 (the best, in my opinion), Poly-Fiber C-2210 (also an excellent solvent), and PPG makes a good paint cleaning solvent but I can't remember the product number.  The water-based paint cleaning solvents don't do much for paint prep cleaning and will likely do nothing to remove adhesive, so don't bother using them.  All of the solvent-based products contain varying amounts of naphtha with other ingredients depending on the manufacturer.
Wet a rag with the solvent, and I mean really get the rag wet - not just damp.  Wipe the surface several times with the wet rag then immediately wipe it dry with a clean, dry rag.  Since the adhesive is old you may have to do it several times.  The solvent will not harm the dope or the balsa.
Tim - I just noticed that you wanted to get the Monocoat itself off of the balsa...the paint cleaning solvents will not do that but they should remove any residual adhesive.  I would try using a heat gun on the monocoat (carefully) to soften the adhesive & pull it off.
Bill Byles
AMA 20913
So. Cal.
« Reply #2 on: July 02, 2017, 02:19:02 PM »
Actually, my question could have been worded better -- there's Monocoat stuck on over dope that needs to come off, but there's also places where the clear mylar has peeled away from the dried-up adhesive.  And even a "perfect" job of removing Monocoat always leaves some adhesive behind.
So you answered my need, if not my question as worded -- thanks.
« Reply #3 on: July 02, 2017, 02:29:04 PM »
Whatever Bill reccommends, I'll go with because of the infinite experience and knowledge he has, but if you only have a small spot or twenty, cigarrette lighter fluid is nearly 100% naptha.  I use it a lot in the shop to remove excess glue spots left from spot glueing, etc. and also clean the wood thoroughly before starting to apply a finish.  (That's on custom guitars.)  So that's a good way to go if there isn't a huge area to do.  I just replenished my "supply" for a buck 95 at Wally-world.
« Reply #4 on: July 02, 2017, 03:00:00 PM »
Whatever Bill reccommends, I'll go with because of the infinite experience and knowledge he has...
If it's about paint, I listen to Bill.  Even if he's just contradicted Mark Scarborough (but then, I'm pretty sure that I've seen him contradict Mark and Mark's response was "listen to Bill").
Offline Larry Renger
« Reply #5 on: July 05, 2017, 10:21:35 PM »
Bill, where does one buy the cleaners and solvents you mentioned? Surely not Home Depot.
« Reply #6 on: July 05, 2017, 11:23:13 PM »
Automotive paint store, I assume.  O'Reilly's had something from 3M called "adhesive remover" with xylene and naptha that doesn't seem to eat the dope -- I'll find out this weekend, unless Bill yells at me, in which case I'll find a real paint store.
« Reply #7 on: July 06, 2017, 10:58:14 AM »
Tim,
consider yourself yelled at. Get a paint solvent from an auto paint store. Tell the guy you are cleaning adhesive from lacquer. He can recommended something they carry. I tend to use pPg or DuPont stuff, but Sikkens is fine as Bill notes.
Offline billbyles
« Reply #8 on: July 06, 2017, 11:26:10 AM »
Hi Larry,
Sikkens M-600 is not available in California anymore - I get mine from an automotive paint supply in Arizona.  Poly - Fiber C-2210 is available from either Poly - Fiber directly at Fla-Bob airport in Riverside or from Aircraft Spruce in Corona.
Bill Byles
AMA 20913
So. Cal.
Offline billbyles
« Reply #9 on: July 06, 2017, 11:28:35 AM »
Hi Tim,
Actually, the 3M adhesive remover should work just fine...I just use the paint cleaning solvents because I keep them in stock.
Bill Byles
AMA 20913
So. Cal.
« Reply #10 on: July 06, 2017, 04:17:09 PM »
Hi Tim,
I thought that was the case -- particularly after dribbling some in an inconspicuous spot and checking -- but it's nice to be sure.
