  • July 14, 2025, 07:24:46 AM
Author Topic: Removing doped on Polyspan  (Read 2116 times)
Offline Mike Griffin
« on: May 07, 2017, 11:49:51 AM »
I have a profile Cavalier that I need to recover.  It is currently covered with doped on Polyspan and the color was yellow dope.  What is the best procedure for removing the current covering down to the bare balsa?  The fuselage was not covered with any type of covering, just painted with the dope.  IF anyone has a tried and proven step by step process for getting the model back to the bare balsa skeleton, I would appreciate the help.
Offline Gerald Arana
Re: Removing doped on Polyspan
« Reply #1 on: May 07, 2017, 12:04:52 PM »
Mike,
Get your self a roll of paper towels and a gallon of acetone. Cut each (full) sheet into quarters......a couple dozen or so, wet them out with acetone and start rubbing! Do about a 3-6" square at a time. It'll take some time but the results are worth it.
That's all there is to it!
Good luck and let us know how you are doing, Jerry
« Reply #2 on: May 07, 2017, 12:30:56 PM »
Thank you Jerry.
Offline Serge_Krauss
« Reply #3 on: May 07, 2017, 07:46:27 PM »
I used Dad's paint stripper (suggested by Randy Ryan), after acetone failed to work fast enough. I worked  more than an hour to remove silkspan from one (of four) panels of my 500 in2 "Primary Force" wing. The paint stripper did the other three in a fraction of that time, with less damage to the balsa from my prying. I don't know why the acetone was so less effective, but at least for my Brodak butyrate, the stripper was superior.
Online Larry Renger
« Reply #4 on: August 07, 2017, 11:44:41 PM »
Amazingly, it was recommended to me to just carve it off with a razor plane! Dang if it didn't work. Careful setting of the cut depth let me take it right down to the wood with no damage to the structure.
Take a look at my Sky Sport in the 1/2 A section to see the result!
