  • June 18, 2025, 10:46:49 PM
Author Topic: Refinishing the Slider  (Read 24055 times)
« on: September 11, 2015, 09:56:40 PM »
So, after flying the old Slider in the last contest (and getting a pretty good score despite a bit of hunting), I decided to refinish it and fix some problems. New flaps and elevators  (the elevators being a large part of the hunting issue) and am not stripping it, but just sanding into the color and repainting. I will post some pictures later if anyone is interested.
This was a very light plane that flew really well and seems to be even better as an electric. I think it will be killer when some issues are corrected.
Re: Refinishing the Slider
« Reply #1 on: September 11, 2015, 09:59:30 PM »
nope,, nobody wants to see you sand off one of your cool paintjobs man,, sheesh
glad its going to prove to be a solid airframe,, in case the tedmobile doesnt pan out
Online wwwarbird
« Reply #2 on: September 14, 2015, 05:51:05 PM »
 Sounds like a plan, just don't use "lead" paint. ;D
« Reply #3 on: September 14, 2015, 08:02:06 PM »
Mark, it's pretty beat up. I could have tried to "fix" the finish but truth is, it had a lot of problems. So, I'll sand it down, fix some issues like refitting the cowl and closing in the pipe tunnel and some other stuff and put a new, killer paint job. And keep it light. No lead paint.
I'll post some pics at some point. Right now I'm fixing all the things that Paul pointed out to me on the Tedmobile. I'd like to get it done for the Fall Follies.
« Reply #4 on: September 14, 2015, 11:29:05 PM »
sounds good,, I am hoping to get some serious flying in,, now that I sorted the issue on the Impact/Prey
charging batteries tomorrow,, as long as it doesnt rain, Or blow,,
John Leidle
« Reply #5 on: September 15, 2015, 01:55:01 AM »
    Randy, what is the clear top coat you mentioned that flowed out so well?   Marc, what did you shoot on your green Nats plane?
« Reply #6 on: September 15, 2015, 09:52:12 AM »
It has one coat of PPG 2021 clear,, ( Urethane),,
and now it sports a lovely contrasting band of glass cloth around its waist LOL
« Reply #7 on: September 15, 2015, 12:12:09 PM »
Mark,
At least it has a belt now. Might keep it's pants up this time.
John,
House of Kolor UC-35 Kosmic Klear with KU150 Kustom Catalyst. I used some pPg urethane reducer though you are supposed to use their RU311 reducer. But mine worked fine. This is their show car clear coat. I sure liked it but it's a bit pricey.
John Leidle
« Reply #8 on: September 15, 2015, 12:35:36 PM »
   Thanks boys.
« Reply #9 on: September 18, 2015, 07:48:13 PM »
Here it is so far. The new flaps and elevators are built but need shaping. Only have about half the fuse sanded with a lot to go including wet sanding.
« Reply #10 on: September 19, 2015, 06:18:05 AM »
Looking good!
Nice font.
« Reply #11 on: September 21, 2015, 04:14:46 PM »
Charles,
The font is called BadaBoom.
Online wwwarbird
« Reply #12 on: September 21, 2015, 09:02:55 PM »
 Just curious, what grit paper did you start out with on the fuse?
« Reply #13 on: September 22, 2015, 11:51:36 AM »
Wayne,
Used 220 Sandblaster paper to cut through the clear then am switching to some 320 Sandblaster. Once done, I will go to 320 wet/dry and wet sand it down. Touch up any areas that need it the shoot base color. So far, it's going fine. Got new control surfaces done and am hinging them now. I also have to refit the spinner.
Online wwwarbird
« Reply #14 on: September 22, 2015, 09:26:56 PM »
 Thanks Randy. ;D
« Reply #15 on: September 22, 2015, 10:22:10 PM »
This was a very very cool airplane,, the color scheme actually was very effective,, but it kind of hid the lines of the airframe,, This needs a pearl and candy finish :)
« Reply #16 on: September 23, 2015, 09:00:50 PM »
Ty,
This had experimental elevators (a failed experiment). the were quite a bit thicker than the stab and very airfoiled. There was zero slop in the system. The idea was got give a good flow from the stab to elevator when deflected and that worked awesome. But it also put the elevators in the airflow all the time and created a lot of turbulence that in turn contributed to the hunting issues. By killing those and going to a more standard elevator I hope to reduce the issues ... and hope I don't kill the awesome flight characteristics.
Online Howard Rush
« Reply #17 on: September 24, 2015, 12:15:31 PM »
How's that?
« Reply #18 on: September 24, 2015, 04:54:57 PM »
Howard,
One of my aerodynamically able friends mentioned it. The fact that the elevators were quite a bit thicker than the stab was said to be an issue and turbulence was noted as an outcome (among others). Hey, I'm an aerodynamic idiot. I just try dumb stuff to see what happens. Sometimes it works. But I do listen to you guys that know stuff after one my idiot ideas fails. I try to correct.
« Reply #19 on: September 28, 2015, 12:41:32 PM »
The new control surfaces are done and the main airframe is about half sanded. Very tedious work. And I keep having to patch areas of sand through. Sigh....
Online wwwarbird
« Reply #20 on: September 28, 2015, 07:11:06 PM »
 That's part of why I asked what paper you started in with. The sandpaper "burn throughs" down to the wood are a pain in the a-- to fix.
« Reply #21 on: September 30, 2015, 05:28:10 PM »
Wayne,
This is more edges of open bays that were probably a bit thin when ti was first painted. Only had problems in a couple of areas but it has delayed the process. But I'll keep plugging away at it. I will shoot a pic with it's ready to paint again.
« Reply #22 on: October 07, 2015, 06:16:49 PM »
Now I'm a bit concerned with the control system. I'm looking down the leadouts and it seems that the bellcrank is very slightly rocking. I'm thinking, as long as I'm here, I may cut it out and put another in. Hmmm....
« Reply #23 on: October 07, 2015, 06:53:49 PM »
Hey I saw a really sturdy bellcrank somewhere in Salem,,, hmm I think it was on the tarmac or something surrounded by a disturbing accumulation of red white and blue balsa,, Just do NOT use that pilot guy he worries me,,
« Reply #24 on: October 08, 2015, 11:56:05 AM »
Mark,
That one is reserved for something else. I have another carbon bellcrank that may see service. The pilot is on the shelf contemplating his misdeeds. I'm considering boiling him in oil.
I may leave it alone. It is solid, just seems to tilt. But I will decide this weekend if surgery is required.
Online wwwarbird
« Reply #25 on: October 08, 2015, 07:29:04 PM »
 Aw heck, what's the worst that could happen?  :##
« Reply #26 on: October 08, 2015, 08:11:13 PM »
DONT EVER SAY THAT,,
that was the last sentance I uttered before my official at the Nats,, After a very trying morning,, I was ready to fly,, told Chris Cox,, " well I got the drama out of the way,, so now whats the worst that can happen",, or something along those lines,, and then,, sigh,,
« Reply #27 on: October 09, 2015, 10:35:43 AM »
I'm more worried about the effect on tracking. I'm not concerned that it will fail so much as it is effecting the plane's ability to track.
« Reply #28 on: October 09, 2015, 01:32:56 PM »
Isn't it better to fix before than after?
« Reply #29 on: October 09, 2015, 03:22:11 PM »
Doc, of course. That's why I'm looking at it now.
« Reply #30 on: October 10, 2015, 08:53:22 PM »
So, in spite of spending much of my day on horses (with the spouse), got most of a new bellcrank made. Will finish that up and cut in there tomorrow. Joy.
« Reply #31 on: October 11, 2015, 08:18:23 PM »
OK, I've never changed out a bellcrank in a plane before, but I have to say that it is no fun. I managed to get the old one out without damaging stuff to much.
but getting a new one in should be just a treat.
Hey, at least the sanding is mostly done. I'll post a pic tomorrow.
« Reply #32 on: October 11, 2015, 08:40:07 PM »
Here are a couple of pics.
« Reply #33 on: October 17, 2015, 06:24:33 PM »
Well, I have the new bellcrank set up about ready. It's, ah, different. Never tried a bellcrank setup with bearing before.
« Reply #34 on: October 18, 2015, 08:09:57 PM »
So, the new control system is in. Smooth doesn't really say it. Now, on the the next issues. This is turning into a lot bigger project than I first envisioned. But it's going to be awesome.
Online wwwarbird
« Reply #35 on: October 18, 2015, 08:58:23 PM »
 Kinda seems like it always does, all part of the fun. :)
« Reply #36 on: October 19, 2015, 10:03:29 AM »
Hi Wayne,
Yea. But I'd rather have something that flies well. And this airframe is about 8 years old so there are a lot of dings, dents and issues to repair. And some minor mods to do. But I think it will be a great plane when I'm done.
« Reply #37 on: October 19, 2015, 01:52:27 PM »
I would note that when inspected the plane, the original bellcrank was rocking around. A lot. So I cut in and discovered that the bearing was shot. Really shot. It was a poor design originally and just didn't work all that well. Lateral pressure was put on the bearing and 300 or so flights pretty much did for it. So, I cut in from the bottom, removing a section of the fuselage and the planking on the wing over the bellcrank. cut the leadouts, cut out the bellcrank mount, disconnected the pushrod and managed to maneuver the bellcrank out. Akin to building a ship in a bottle as I cut a fairly small hole (see picture above). I used some music wire to thread back into the wing, attached new leadouts with Brett Buck style ends and drag them back through the wing and out the leadout slider. Getting the new bellcrank in along with the new mounts (with integral bearings) was nightmarish, but was eventually done. Attaching the leadout to the bellcrank wasn't too bad but rotating the bellcrank in the wing to reattach the pushrod was just not fun. Had to disconnect and reconnect it 4 times as I had to adjust the pushrod length (the bellcrank didn't go back exactly in the spot as the original - close but not exactly) to recenter the horns and bellcrank together. Then I reinforced the area , put in new ribs and bridged the edges of the sheeting, put in new sheeting and replaced the section of fuse that was removed.
Hopefully, I bridged the area well enough that the thing won't fly apart when I fly it. This was a really light plane and I don't want to add significant weight to it. Now I just have to grind down the filler put in the areas were I cut the fuse, modify the elevator horn to allow a bit more adjustment, refit the spinner area then I can finally get on to painting.
It was a great flying plane before (despite it's tracking issues which are hopefully now fixed).
Ain't life grand.
Online wwwarbird
« Reply #38 on: October 19, 2015, 06:52:45 PM »
 Do you think that the wear of the bellcrank bearing had anything to do with the tracking issue?
« Reply #39 on: October 19, 2015, 10:01:29 PM »
Wayne,
Almost certainly. With it rocking around like the, I'm surprised I could get it to track at all.
« Reply #40 on: November 02, 2015, 12:39:47 PM »
So, the base color is on. Finally. This ended up being a lot more involved than I had planned.
« Reply #41 on: November 02, 2015, 03:11:37 PM »
It's the list of honey-dos that takes all the time.
« Reply #42 on: November 07, 2015, 05:13:00 PM »
So, base color and canopy is on. For once, it actually looks better in person than in the pictures. Go figure.
« Reply #43 on: November 08, 2015, 07:12:03 AM »
Randy,
Really nice canopy lines.  H^^
Looking good!
Charles
« Reply #44 on: November 08, 2015, 07:18:43 PM »
6 hours of taping for 15 minutes of painting trim. Joy.
Online wwwarbird
« Reply #45 on: November 08, 2015, 08:47:14 PM »
 And...?  #^
« Reply #46 on: November 09, 2015, 04:58:33 AM »
Typical. And it takes almost as long to remove everything. Especially if there's layers.
Charles
« Reply #47 on: November 09, 2015, 10:18:49 AM »
Yea, I pulled tape late last night. Looks OK. As a couple of places that will need a bit of touchup, but overall, not bad. The colors are pretty cool. Problem is, I'm not sure where to go next. Red maybe, or blue. Perhaps some off beat tonal match. Hmmm.... There will be a bit of black or maybe some checkerboard. We'll see.
I'll post a pic later just for Wayne. Can't have him wondering.
« Reply #48 on: November 09, 2015, 08:46:06 PM »
Here you go, Wayne.
Online wwwarbird
« Reply #49 on: November 09, 2015, 09:15:30 PM »
 HA! Thanks Randy, always curious about what's happening at the Powellworks!  y1
